![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
Front Brembo bolt head, what is it?
Front brembo caliper bolt (center) what is the socket type called that fits this head? and it has to have a MM size. The best I can come up with is 10T x20mm.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Try a normal 6 or 12 point metric socket, it will probably work
"KEEP THE FAITH"-Fbodfather |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
I “believe” the CORRECT tool is a 10 point caliper brake socket.
1.03 from this video… Last edited by Chutzpah; 12-12-2022 at 08:02 PM. |
![]() Drives: 2016 Camaro Join Date: Oct 2017
I did a search and both Summit Racing and Amazon have some sockets in different brands.
No doubt specialty tool venders like Snap-on also will.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
#5 | |
Hot Camaro
I think @chutzpah has the right tool called out - just a matter of ensuring one gets the right size. |
Thanks to everyone for the information. The video from summitt showing a guy changing the front brake pads on a C8 Z51 corvette is exactly what my front calipers look like and exactly how they are designed. The LT1 certainly has a great front brembo brake set up. The special 10 point socket is what I need, just need to find out what MM it is. A 7/16 regular socket is loose, a 3/8 socket is too small, would that mean the bolt head diameter is around 11 MM?
#7 |
#8 | |
Hot Camaro
ETA: Apparently, "some" Brembo calipers use a socket that's 11.5 mm... |
#9 | |
https://www.amazon.com/Caliper-Impac...9LVDXVPK&psc=1 |
#10 | |
#11 | |
But getting the correct socket is definitely the way to go for full confidence.
#12 |
I would put a set of calipers on it and measure point-to-point and groove-to-groove.
Everything I find shows 11.5 mm is the smallest socket on a brembo. You can buy that individually on amazon, again with free returns. So what's the risk? I wouldn't even bother driving to autozone. |
#13 |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Did you ever get the correct info for this?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
#14 |
Its available thru the tool guys and your better auto supplies. I carried a picture on my phone to show them. BY the way Joe, email communications are easier for me than thru PM on this site. You have my email address, use it anytime you want.
Thanks Don |
