Old 12-10-2022, 07:48 PM   #1
ALC
Drives: 2016 Camaro SS M6
Are the tire air deflectors necessary?
I recently bought an SS and the tire air deflector pieces are gone. Are they necessary to replace or can I leave them off? Will it impact cooling? Here’s a link to a picture of the part I’m talking about: https://imgur.com/a/1CFIoMb
ALC is offline   Reply With Quote
Old 12-10-2022, 08:00 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I don't think they are so much cooling as they are to deflect air around your tires to lessen any lift they may produce... I think you'll be fine without them...
Old 12-10-2022, 09:50 PM   #3
I installed a front splitter and got rid of these eyesores for good. Not only does the splitter look sharp, it also helps with downforce and alleviates the need for these deflectors to some extent.
For the record, the ZL1 has a much better tire deflector design, but unfortunately those pieces aren't a direct swap with the SS parts.
Old 12-10-2022, 11:10 PM   #4
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I think they are called splats. I think they are worth having, not expensive and not as prone to damage as a splitter. They help with aero by keeping some air from getting in fender well.
Gen6cyl is offline   Reply With Quote
Old 12-12-2022, 11:01 AM   #5
ctrlz
Those pieces of rubber are there for fuel economy. They reduce drag by directing air away from the tires. When air hits the moving tire tread it creates vortices. That causes more drag.
This is the type of thing that is mainly there for when they EPA certify the car. Going around the track 100 times it may add 0.1 mpg. With a car like this they need to milk those tenths for all they can.
Old 12-12-2022, 11:15 AM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
nope not necessary
Old 12-12-2022, 11:30 AM   #7
Osbornsm
Drives: 2018 SS 1LE
for MPG, NOT for cooling.
SS 1LE doesn't have them.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 12-13-2022, 06:13 PM   #8
ALC
Makes sense, thanks for the explanation
Old 01-11-2025, 01:25 PM   #9
CorvetteRon
Drives: Camaro, Corvette
Air Deflectors
I have one of these air declectors in front of each front tire on my '23 SS.
They prevent me from using my garage ramps, so I have to remove them to do oil changes, etc. Not a problem.
But there is no noticeable driving differance if I procrastinate in reinstalling them.
CorvetteRon is offline   Reply With Quote
Old 01-11-2025, 02:15 PM   #10
p47dman
Drives: 2024 Camaro 1SS
Mine came with replacements parts. Stated if going to track replace the standard ones with the upgrade. They are for cooling the brakes.
p47dman is offline   Reply With Quote
Old 01-11-2025, 04:33 PM   #11
2SS Capt
2SS Capt's Avatar
You are talking about the brake cooling deflectors, those are different than what the OP was talking about (the tire air deflectors that you can see under the car in front of each front tire)...
Old 01-11-2025, 08:08 PM   #12
p47dman
Pretty sure you are supposed to remove stock deflectors and replace with performance parts. After track remove them and reinstall stock deflectors.
Old 01-11-2025, 08:30 PM   #13
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
prevents Air lift for the ZL1 SS not so much.
IMCWORTH is offline   Reply With Quote
Old 01-11-2025, 08:54 PM   #14
p47dman
My instructions also say do NOT drive without them.
