Old 12-07-2022, 06:55 PM   #1
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Quik Magnuson 2650 ?
Yes or no will a magnuson 2650 set at 13 psi get me to 700 whp on 93 as stated
And everything else basically stock minus headers intake and E
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 12-07-2022, 09:01 PM   #2
Z OH 6
Drives: 2021 Red Hot ZL1
So you do have headers and intake? The way your post is worded is confusing You mention E but want 700whp on 93.
Old 12-07-2022, 10:01 PM   #3
SATINSTEEL1LE
Drives: 21 ZL1
I got just at 700rwhp with maggie and small rotofab, no headers nothing on 93. 90mm pulley seeing 14psi.
SATINSTEEL1LE is offline   Reply With Quote
Old 12-08-2022, 12:00 AM   #4
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
That's about the edge of the stock fuel system. Even with BaP.
Schlok is offline   Reply With Quote
Old 12-08-2022, 08:08 AM   #5
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
I’ve made 740 with Maggie, full exhaust, and rotofab. Low side starting running out at 690-700 do I didn’t a JMS bap. High side was on the edge.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 12-08-2022, 08:27 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I know a couple others, with similar mods', making a little more than 700 (non-SAE), too. I haven't made it on a dyno, personally, but feel pretty good about the prospect of being around there, too. Or - at least close.
'20 ZL1 Black "Fury"
Old 12-08-2022, 08:28 AM   #7
Future1LE
Drives: 2020 Chevy Camaro ZL1 1LE
Yes you should be around 700 on a magnuson 2650 with headers,intake and tune on 93. Like everyone said, that will be the limit of the high side.
Future1LE is offline   Reply With Quote
Old 12-08-2022, 09:33 AM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
As a comparable reference, I'm dynoing my Eddie tomorrow on 100 oct. with OEM high side and DSX low side and expect to make around 1000, corrected. Rail pressure runs around 3000 psi and low side 80 psi. Boost will be 20-21#
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 12-08-2022, 04:42 PM   #9
KILLA BEE
Black lightning
KILLA BEE's Avatar
Yes I have headers and an intake
Old 12-08-2022, 04:43 PM   #10
KILLA BEE
Black lightning
KILLA BEE's Avatar
Wow that’s really good. That’s basically all I would need. The E would be extra then I’d have to get meth, cam or possibly a jms booster. So I’m guess the 90 mm pulley swap is sufficient
Old 12-08-2022, 06:06 PM   #11
SATINSTEEL1LE
Drives: 21 ZL1
Yeah should be but you might as well order that JMS Bap now. I was out of low side on just what I have, no headers or anything else. I have the JMS now and my low side is all good.
Old 12-08-2022, 06:21 PM   #12
Z OH 6
If that's the case, a Maggie 2650 should get you close to 700whp on 93 octane, I suspect it will take close to 15psi of boost but its certainly doable.
Old 12-08-2022, 07:49 PM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You’ll need 15psi, you’ll be under 700 SAE.
700whp your high side pump will be completely maxed out at 130degrees and your inj pw, rail as well Goes with it.
I would say more like 680 SAE, it will be close.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 12-08-2022, 08:16 PM   #14
SATINSTEEL1LE
Drives: 21 ZL1
Lots of “facts” you spreading there. Lol
