Old 12-05-2022, 10:18 PM   #1
Blast2hell
Drives: 2020 ZLE Rally Green A10
Brake pad size problem
I got a set of front Hawk DTC 70 pads, and three of them slide right into the caliper, but a fourth one will not go in. I can put any of the other three pads in, but this fourth one just seems to be too wide. When holding the pad back to back with the others, the size difference is almost imperceptible. Actually visually I can't tell but holding my fingers against it I can.
Got a track event this Friday....I can call the place I got them from and ask for a replacement I'm sure, but doubt they will get here in time for Friday. Should I file the edges?
2020 Rally Green ZLE A10
(SOLD)2017 NGM ZL1 A10 Built 3/31
Sebring Best Lap Time 2:29 Video
Roebling Road Best Lap Time 1:25 Video
Blast2hell is offline   Reply With Quote
Old 12-06-2022, 08:53 AM   #2
easttxss
easttxss's Avatar
Drives: '16 2SS M6
If the pad looks the same otherwise, I would grind it down to fit.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 12-06-2022, 09:29 AM   #3
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Is the piston on that side fully retracted?
Old 12-06-2022, 10:46 AM   #4
easttxss
easttxss's Avatar
Drives: '16 2SS M6
He said it was too wide and that the other 3 pads fit. The piston locations have nothing to do with that.
David
'83 Jeep Wagoneer
Old 12-06-2022, 11:31 AM   #5
ctrlz
I would do the same. I would probably break out a set of calipers and take some measurements, then go a little bit at a time. I bet there is some casting flash that got missed and painted over.
I would skip the file, that will take forever. Decent angle grinder is like $17 at harbor freight if you need one.
