Old 12-04-2022, 04:20 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
Can't Log AEM 30-0334 X-Series OBDII Wideband !
Help!
I'm using the AEM 30-0334 X-Series OBDII Wideband (gauge, sensor, and OBDII pass-thru connector).
But I can't add AEM's WB channel (WB EQ Ratio 1 SAE) to my HPT channel list to scan and log WB data. The scanner greys-out the WB channel description (WB EQ Ratio 1 SAE) then removes it on engine startup.
I have attached an image on the right below of what I see when I click the gear with green + sign in the channel section heading and go to "Add channel."
Guys on the HPT forum today say that I shouldn't use any channels under External Inputs and point me instead to the OBD controller channels shown below in light blue on the left that my scanner doesn't have.
I understand this stuff is fairly common. Anyone solved this issue? Thanks
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-04-2022, 06:04 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Two thoughts here and suggestions:
1) You can repoll to see if it populates
2) Read here for past problems
https://forum.hptuners.com/showthrea...960#post625960
Old 12-05-2022, 08:33 AM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
My WB was working in HPT two weeks ago, so the issue of whether it's CAn or OBD doesn't apply. What mode is your gauge in with the engine running?
2020 ZL1LE A10.
Old 12-05-2022, 09:09 AM   #4
SATINSTEEL1LE
Drives: 21 ZL1
Are you also adding the PID for the gauge itself?
SATINSTEEL1LE is offline   Reply With Quote
Old 12-05-2022, 09:23 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
This video explains it as simple as it can be. The only thing that isn't mentioned in the video is the car needs to be in SERVICE mode while performing the setup.
Also, make sure the wideband itself is ON, past the "heat up" phase, and showing numbers before you attempt to connect and repoll parameters or else Hpt will not read it...and will remain grayed out in the channel list.
If this doesn't work, then you have other issues.
Old 12-05-2022, 10:02 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
This video explains it as simple as it can be. The only thing that isn't mentioned in the video is the car needs to be in accessory mode while performing the setup.
My WB does not turn on with accessories, only with service mode or engine start. I watched AEM's videos a gazillion times, so many that I think I'll do my own video! They don't get to the issue at hand here, and my channel list does not look like theirs.
2020 ZL1LE A10.
Old 12-05-2022, 10:05 AM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
First of all, what is PID? I assume it's an informal abbrev for something.
I don't see a channel that looks like your image.
2020 ZL1LE A10.
Old 12-05-2022, 11:48 AM   #8
KingLT1
KingLT1's Avatar
The WB EQ1 channel(PID) is already added. Put the car in Service mode and follow what I said previously. It needs power in order to be read by scanner.
The confusion is what mode to have the car in. You need to longpress the start button for 5 seconds so everything powers on without starting. I said accessory mode but if it's actually called Service mode that's where it needs to be.
Old 12-05-2022, 12:27 PM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
If you're having trouble using the AEM X-Series OBDII WB channel in HPT, try this:
1. Delete contents of folder, HP Tuners\VCM Scanner\Vehicles
2. Download current HPT Suite (or Beta) and MVPI drivers,
3. Connect the laptop to OBDII,
4. Put the car in service mode,
5. Wait 20 sec. for WB to power/warm up,
6. Select mode "obd2" on the AEM gauge,
7. Close Editor and open Scanner.
8. Click "connect to vehicle" in scanner,
9. Repoll vehicle parameters,
10. Click gear icon with green + "add channel"
11. [add new channel] dbl click "WB EQ Ratio 1 SAE " under OBD2 [I don't remember the entire tree]. Do not click any External Inputs.
12. Click "Start Scan", the WB channel should remain in list and display active scan data.
13. Push ignition button to exit service mode.
14. Start engine, start scan, and the WB channel should display active scan data.
So, at least for today, it's working. Thanks everyone.
2020 ZL1LE A10.
Old 12-06-2022, 07:21 AM   #10
cjperformance
cjperformance's Avatar
PID is "Process ID" afaik. Its an identifier for the type of data it is sending on that channel.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 12-06-2022, 08:37 AM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
I'm still not sure about PID, nor am I 100% sure which of the steps I listed solved my WB problem, but if I had to guess, I would say selecting obd2 mode in the AEM gauge.
2020 ZL1LE A10.
Old 12-06-2022, 09:53 AM   #12
KingLT1
KingLT1's Avatar
I don't understand how selecting obd2 mode would suddenly make it work when it was working before unless you accidently changed it.
You likely were not waiting long enough for the wideband to turn on and get past the heat up phase before attempting to connect to it.
PID's are the technical term for the channels you log(ie: Map, MAF, RPM, IAT...etc)
Old 12-06-2022, 11:19 AM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, I had inadvertently changed the AEM mode, but never paid any attention.
I always allowed plenty of time in service mode for sensor warmup. Should I rewire it so it turns on in Accessories too?
2020 ZL1LE A10.
Old 06-23-2026, 09:55 AM   #14
CountySS
I had to use AI t9 help me get it to. Work for logging. Took a little while but got it work8ng.
CountySS is offline   Reply With Quote
