![]() Drives: Chevrolet Camaro Join Date: Jul 2022
Big brake upgrade
Hi guys,
I own a Gen 6 SS and would like to upgrade the brakes. Do somebody know if the ZL1 brakes will fit these aftermarket 20“ wheels? Aftermarket: 20 x 9.5 offset 22 20 x 11 offset 40 Name: Wheelforce CF2 Flow forged And these stock wheels attached? Or do I have to mount the SS 1LE brakes? https://imgur.com/a/HSDH8Bj Last edited by robka; 12-05-2022 at 07:28 AM. |
#2 | |
![]() Drives: 2016 Camaro SS Join Date: Oct 2021
I just installed the GM kit on the front last night and it was a very quick and easy install.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have the zzp bbk on my ss uses ctsv2 calipers and oem 1le rotors havent ever tried 18s but it fits 19s and 20s no issues
#4 | |
The rears on the ZL1 are the same as the normal SS? I thought they're also bigger. SS 1LE does have the same rears as normal SS. I know that the SS 1LE brakes should fit without a problem. But what about the ZL1 (1LE) brakes? |
yes they would fit no problem they are just a lil bit bigger
Physically I think they are the same size.
#7 |
Nah, the ZL1 1LE (with J6H brakes) has even larger rotors and calipers than the SS 1LE (with its J6M brakes), both front and rear, see below. The differences are not huge, but not negligible either.
#8 | |
Also the rear ZL1 calipers are the same size as the SS/SS 1LE calipers? This means that the max wheel offset is the same as the SS 1LE... Then I don't know why a guy with a shop told me to buy "his" brakes, because the ZL1 won't fit. I searched his online shop and he's selling the gm performance brakes which are equally to the SS 1LE. ![]() Where do you get the information that the calipers are different in size? I can't read it from that. |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
#10 |
It is possible the bigger ZL1 calipers might have a clearance issue to your wheels, but you could run a small wheel spacer to pop the wheels away.
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
#11 | |
Unfortunately you’re not allowed in Germany to let the wheels stick outside the chassis. When I would install a spacer on my aftermarket wheels the offset would be too high and the wheels would stick out of the wheel housing. |
#12 |
Your wheel and tire combo already sits inside the fender more than the wider SS 1LE wheel and tire package would, so if you added that extra 3mm or so by way of a spacer it would not stick out past the fender.
#13 | |
Nevertheless, ZL1 1LE calipers have different part numbers and fitment information from the SS 1LE (part numbers 84229190/84229191 vs 84063672/84063673, feel free to check online catalogs at parts sites). I'm no brake expert by any means, but it makes sense, too, given that ZL1 1LE rotors are 20mm wider, thus reusing the same calipers and pads from the SS 1LE would mean having the same friction surface against a larger rotor, reducing braking efficiency gains that the ZL1 1LE's super grippy tires afford.
#14 |
I think I'll go with the SS 1LE then and open a wtb thread. Maybe someone is selling their brakes.
Thank you guys. |
