![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Jannetty Racing Professional Remote Calibration services
Modifying your car?
Then you need Professional Calibration services from Jannetty Racing. Have or need a Tuning Device? https://jannettyracing.com/collectio...uning-packages Anything from a Cold air kit to 1000+ Horsepower builds, JRE is your source for professional calibration services both Remotely and at our headquarters in Waterbury CT. Calibration services for N/A builds, Performance cams, Superchargers, Turbos, Torque converters, built transmissions, Gear ratio, and tire changes. We do not calibrate for NOS systems, that is up to the owner, as there is too much risk of engine failure and it's always the tuners fault LOL. We do not support or offer Pop, burble, backfire, car show nonsense. Instructions can be found here for HPtuners. https://jannettyracing.com/pages/jan...g-instructions Any questions please ask, I will be happy to help. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 12-04-2022 at 09:40 AM. |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I dont know if this is needed, but i can vouch for TED and the benefits / advantages of remote tuning for those of us without a reputable tuner near by.
I have heard so many horror stories of the "local guy" who said he could tune my car, and then disaster! To be honest, even though TED is great, this is tricky without a good general understanding of how HP tuners works. As much as i suggest using TED, i also suggest you watch some HP tuner 101 videos before getting started. This will speed up the process, and prevent you from wasting time when the process starts. I have had many sports cars, and had a few of them modded and tuned, and being a DIY kind of guy, I really enjoy the "street tune" vs. the "dyno tune". Im not saying that one is better than the other, but when you street tune your car, over the 3-10 data log / tune change process (depending on mods) its cool so see and feel the changes, and it allows you to provide TED realtime feedback (idle, fans) etc as you go, to make sure the car is just the way you like it. Also, the part i appreciate most, is the peace of mind of how he eases into WOT. For example, with my recent cam swap, we have 2-3 data logs with no boost before he even suggested one. Makes me alot more confident with the process, vs. potentially leaving your car with someone who might be hammering on your car before it's ready. We all know the world class shops that DONT do that, but for some of the smaller or UN-experianced wanna-be shops that you need to be aware of. Anyway, thats my 2 cents...
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
Thank you for your business and your kind words.
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
![]() Drives: 2002 Chevrolet 2ss 1le Join Date: Jun 2022
How does remote tuning work if I don’t have a wideband? Is it possible? Just basic bolt ons? Header, intake manifold, 103mmtb
#5 | |
Wide band is part of our Remote tuning packages. Factory O2 sensors are only in play during normal driving. The wide band is there to read AFR during full throttle Operation and allows us to dial in Full Throttle Fueling and timing for optimum performance. Ted.
We have now sold out of MPVI2s and are stocking the MPVI3 as well as Prolink cables.
#7 |
SIK SS
Drives: 2016 Black 1SS Join Date: Apr 2016
I did the cam, lifters, push rods and springs through Ted and remote tune. Great experience and Ted seems to be a stand up dude with a lot of knowledge. Thing ran like a champ for over 4 years with just regular maintenance.
Recently had issues with surging at idle but only when the car was warmed up. Seemed a bit worse during the hotter months. I don’t drive her much but I keep additives in the fuel most of the time. Then it started happening this winter as well. Then the sputtering and then nothig. It’s so bad now the car will not start and idle. Ran my scan tool and see 2 codes. P050D and P00C6. I’m leaning towards injectors but should I pull the high pressure pump and check for unusual wear? Low pressure pump is working but I haven’t checked the pressure yet. Will do so today after the fittings that I need come in. I think 55 psi is the magic number? Anyway, thoughts, comments, suggestions? I’m sorry if I sort of jacked this thread. I wanted to make sure Ted could chime in. Thanks guys |
#8 | |
You can diagnose those codes, same as if car was 100% stock using the Diagnostic protocol for those codes.
#9 |
#10 |
Thanks for all the business.
#11 |
Modifying your car?
Then you need Professional Calibration services from Jannetty Racing. Have or need a Tuning Device? https://jannettyracing.com/pages/tuning-services Anything from a Cold air kit to 1000+ Horsepower builds, JRE is your source for professional calibration services both Remotely and at our headquarters in Waterbury CT. Calibration services for N/A builds, Performance cams, Superchargers, Turbos, Torque converters, built transmissions, Gear ratio, and tire changes. We do not calibrate for NOS systems, that is up to the owner, as there is too much risk of engine failure and it's always the tuners fault LOL. We do not support or offer Pop, burble, backfire, car show nonsense. Instructions can be found here for HPtuners. https://jannettyracing.com/pages/jan...g-instructions Any questions please ask, I will be happy to help. Ted. Fixed the links for our newer web site be sure and click on the links in this post.
#12 |
Take a look at the site we just updated all the remote tuning pages.
#13 |
Tuning is a never ending evolution, As HPtuners adds more access we are able to do more.
The latest release has given us Gen5 ECM Throttle body calibration tables which was not available since Gen4 ECM
#14 |
Black Friday Deals on tuning with purchase of equipment.
