Old 12-02-2022, 10:50 PM   #1
wang970305
Drives: 2021 Camaro 2SS
Catch can brace bolt torque?
I’m installing a mishimoto catch can on my 21 SS?
I’m wondering what’s the torque on those two bolts?
wang970305 is offline   Reply With Quote
Old 12-02-2022, 10:54 PM   #2
Guten tight
Old 12-02-2022, 10:56 PM   #3
Okay, okay, Friday tongue-in-cheek time is almost over, here's the actual spec for you (16 lb ft).
Old 12-02-2022, 10:58 PM   #4
wang970305
Appreciate it!!!!!!!!!!!
Old 12-03-2022, 01:24 AM   #5
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I installed mine on my 20 2SS and I honestly used "Guten Tight", they are hefty bolts and I wasn't too worried about proper torque... Been in place for 3 years with no problems...
Old 12-03-2022, 07:58 AM   #6
cjperformance
cjperformance's Avatar
Guten tight
Bless you. Here's a tissue for your cold.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 12-03-2022, 07:59 AM   #7
cjperformance
Sorry... dumb joke they used to say at the shop i worked at years ago.
Old 12-03-2022, 08:11 AM   #8
Gotcha! (see, now you can say it again )
Old 11-19-2023, 01:15 PM   #9
Camaro455ss
Camaro455ss's Avatar
Drives: 2016 Camaro 2SS ... 2024 Camaro 2SS
The number 2 "10mm " plenum bolt on mine snapped off... whats the part number on it? It cant be 80 ft lbs as mine snapped off.
Camaro455ss is offline   Reply With Quote
Old 11-19-2023, 01:22 PM   #10
2SS Capt
2SS Capt's Avatar
It says 80 lb/in, not 80 lb/ft
Old 11-19-2023, 01:22 PM   #11
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
80 inch pounds not foot pounds
6.6 ft lbs if you don’t have torque wrench in inch pounds
Old 11-19-2023, 02:48 PM   #12
Camaro455ss
Oh FFS:conf used0068::confused0068 :
wtf did i do :'(
Old 11-19-2023, 02:49 PM   #13
Camaro455ss
well i snapped it off... :'(
im trying to carefully drill it out!
Is there a part number i can ask my chevy dealer tomorrow?
Old 11-19-2023, 05:13 PM   #14
CalgaryZL1
CalgaryZL1's Avatar
Sorry I don’t have a part number, but it might be easier to remove the brace and then unscrew the broken thread from the other side so you don’t have to do a bunch of drilling
I’m guessing it’s probably a 10 mm bolt which you could get anywhere or take the broken piece to the dealership along with the photo from this thread so they can get an idea where it came from
