Old 11-30-2022, 12:32 PM   #1
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Custom made Exhaust tips
Since alot of you guys asked, I had the factory make some more custom ZL1 exhaust tips.
They are black gloss plated, with the ZL1 engraving.
Stainless Steel SS304.
60mm id inlet, 114mm outlet. They slip right over the oem exhaust pipes, but need to be welded on.
Selling a set of 4 for $320 including shipping within the US. (Lower 48 states)
(Will list the SS set separate)
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
