Old 11-28-2022, 10:21 PM   #1
JJR11
Drives: 2021 Chevy Camaro ss
Installed headers and I hear a tick
Yesterday I installed my speed engineering headers on my 21'SS today I got home from work and heard a more noticeable tick coming from the passenger side area header from what is sounds like. I know these engines have direct injection and from what ive heard are very loud! Especially once u add headers that are made from thinner material compared to stock ones that use way thicker material. Have any of yall had or heard tick after header install? And ive made sure this is not an exhaust leak 100% I checked all the bolts and they were all good.
JJR11 is offline   Reply With Quote
Old 11-29-2022, 09:26 AM   #2
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Sounds like Timing. Have you tuned the car yet?
You should tune after header install. And you should not drive on it untuned for any extended amount of time, 1-3 months or more.
Things can and do break when not tuned.
Old 11-29-2022, 12:24 PM   #3
musclesbmf
Drives: 2020 ZL1 1LE A10
Valve train and injector noise you're hearing through the long tubes.
musclesbmf is offline   Reply With Quote
Old 11-29-2022, 12:27 PM   #4
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
As mentioned above, I can almost guarantee that you can now hear injector noise through the headers. Most of those headers are thinner walled than their cast counterparts and will transmit more noise through them. Sometimes it can be loud enough to trigger your knock sensors.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 11-29-2022, 01:22 PM   #5
FlukeSS
FlukeSS's Avatar
Also I don't hear ticking in my engine with my headers.
Old 11-29-2022, 02:01 PM   #6
laynlo15
Drives: 2022 Lt1 A10
I'm guessing he has a small exhaust leak. Look for any black soot around the clamping areas. Mine had that and I went to a larger 3" stainless band clamp. The little clamps that come with them don't always seal up very well. I agree, you may be hearing noise from the header itself since they are very thin compared to the stock manifolds and cats. You need a tune for sure.
Old 11-29-2022, 02:21 PM   #7
easttxss
easttxss's Avatar
Drives: '16 2SS M6
Best way to locate an exhaust leak is to use 3'-4' of vacuum hose. One end in your ear, the other to listen around all sealing areas.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 12-01-2022, 05:39 AM   #8
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Some ticking is normal but if its loud and very noticeable, its likely an exhaust leak.
You may only need to re-torque the head bolts as they can get a little loose after a heat cycle on a new install.
Spaceme1117 is offline   Reply With Quote
Old 12-01-2022, 06:57 PM   #9
Bob RS
Drives: 2019 Camaro RS 1LT
More then likely you have an exhaust leak
Bob RS is offline   Reply With Quote
