Constantine the Great
I just changed my own spark plugs, and it seems they are Carbon fouled.
Even though, they been changed at 50k miles after one of the coils failed. Would these cause damage to any of my engine parts? Knock sensor? and coils? Just curious...
In Hoc Signo Vinces
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Have you made some aftermarket changes to the engine? How about a tune?
While these plugs aren't as pristine as one might expect, with the exception of #4, they don't look bad. You're hoping for minimal black carbon build up and for the ceramic surrounding (insulating) the center pin to be a nice tan color. I don't think you ever find that on a modern FI, DI, VVT engine. They're just trying to be frugal with fuel and burning it hot, so you get some blackening around the edges and the center ceramic is more white (lean mixture) than tan. As I said, it does look like #4 is either burning cooler or getting a richer mixture of fuel. Is that the plug with a bad coil? That would explain its appearance perfectly. I don't think the condition on these plugs would cause any harm to the other components you mentioned. I think you are good to go! ![]() On review I've got to say those pics do show a nice tan hue on the center insulators, with a little extra black on #4. |
Monterey County Camaros
Drives: Stock 2016 Camaro V6 Join Date: Nov 2019
I changed my spark plugs at 105,000 miles. Yours look way worse than mine did.
One on the left is old, right is new. I'd backtrack. Start with the fuel. I run only 91 and do the occasional Chevron Techron Complete Fuel Cleaner. I try and stick to either Shell or Chevron. If neither are available, choose another fuel that's a race team (Valero, 76, Texaco). I'd check the coilovers and make sure they look good. With the spark plugs, make sure they're torqued correctly. Think it's like 18. If you don't run the car hard, it might be beneficial to drive it like you stole it every now and then. A buddy and I believe that performance cars need to be run hard to keep the parts working properly.
#4 | |
In Hoc Signo Vinces
#5 | |
I have a feeling i should put back the stock inlet with the baffle to reduce the amount of carbon my car is making from oil. I use 98 octane Fuel.
In Hoc Signo Vinces
![]() Drives: 2020 ZL1 1LE A10 Join Date: Feb 2021
Normal wear on those plugs.
Stock tune I'm assuming? |
#7 |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Spark plugs don't look to bad.
But to me it looks like you are burning some oil. How is your oil level? |
#8 |
Drives: 21 ZL1 Join Date: Feb 2022
As long as the fuel trims are not maxed out negative, then you are not running rich. But you would need to log the car to see what the fuel trims are doing in real-time. But running rich is a relative term. A car is only running rich if the fuel trims are unable to pull enough fuel to keep the car at stoich. + or - 5% on the on the long term fuel trims would be fine. The car is able to add or pull fuel as needed to keep stoich. Its only if you are putting in too much fuel and the PCM is at the limit of what it can pull out, that you'd actually be "running rich".
The car uses the MAF as well as the o2 sensors to measure the car's air flow, and in turn calculate its fuel needs. I'd start by cleaning your MAF with the MAF spray cleaner and I'd think about replacing the o2 sensors. Also unless you are modded, skip the 98 octane fuel. 93 is more than fine for a stock SS/RS. |
#9 | |
![]() Drives: '16 2SS M6 Join Date: Aug 2019
I agree with cleaning the MAF and replacing the front O2 sensor, they do wear out.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
#10 |
OP's plugs look pretty good. I think the photo is a little underexposed because the camera is adjusting for the wooden background.
Most of the world uses RON (research octane number). USA uses AON (average octane number, (R+M)/2 as the pumps say). RON-5=AON |
#11 |
![]() Drives: LT1 Join Date: Mar 2022
If I had one dirty plug like that, I would run a compression check.
#12 |
Catch can will help. Pull the intake manifold and you will likely see oil residue coming from the PCV. That oil eventually makes its way to the cylinders.
Edit* I see you have a 4cyl turbo. Check to make sure the turbo isn't leaking oil.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 12-02-2022 at 11:23 AM. |
#13 |
![]() Drives: 2021 C8, 2022 Camaro 2SS Join Date: Jul 2015
I would expect all plugs to look about the same. Your bottom one in the photo does not. Appears your car is 2.0L turbo 4? Is so plugs suggested by GM in USA market are 12681659 not the number on your used plugs? You mention plugs were replaced once at 50K, so how may miles on plugs in photos?
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022 3400 1/25/2022 TPW 1/31 3800 2/15/2022 4300 2/19/2022 4B00 3/04/2022 4000 3/8/2022 Delivered 3/9/2022 ____________________________________ Order 6/01/2016 2017 2SS, NPP, 56R whls 3000 6/08/2016 3000 6/15/2016 TPW 7/18/2016 3400 7/7/2016 4200 7/25/2016 Delivered 7/28/2016 Sold May 2020 |
#14 |
