![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
Catch Can Results
I took the supercharger lid off after 12,000 miles running the Elite Engineering E2-X catch can. I'm pretty happy with how clean the inside looked.
I get about 2-3 ounces of nasty goo every 2000 miles or so when I drain the catch can and change the oil. The mount was welded on the back side where it pivots, so the catch can does not move at all. Engine is stock. I proactively replaced the oil pump with a Katech unit, since I don't plan to ever sell it, which is ultimately the reason for the catch can. |
Drives: 21 ZL1 Join Date: Feb 2022
My 21 without a catch can for the first 4k miles of its life looked exactly like that with oil in the same places as well. Catch cans are not needed.
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Oh here we go again with the catch can debate. Just let who ever wants to install them do it doesn't hurt and it's a plus if it works. I personally love my Elite E2-X Ultra
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
Exactly. Catch cans, particularly for these cars, are a great way for aftermarket companies to make $$. You're still going to have to get the valves cleaned at around 70k miles anyway.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
I did not intend to re-light this tiresome debate. This post was for those curious about how the can worked, and my thoughts about my particular installation.
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Add some boost and then check it again.... Plus the crap in the can is going somewhere...
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
