11-22-2022, 12:45 PM | #1 | |
Drives: Nickey Super Camaro Join Date: Nov 2008
NicKey ZL1 Stage II Option w/Port injection
Matt Peckham of NicKey Performance discussing the details of the build. |
11-22-2022, 04:19 PM | #2 |
These port injection setups are proving to be a good fueling option for FI cars.
Thanks for sharing your experience and the video. Nice job!
11-23-2022, 02:50 AM | #3 |
Drives: Camaro ZL1, Golf GTI Join Date: Feb 2022
Should have come from the factory with dual injection
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT |
11-23-2022, 06:44 AM | #4 |
This is what I have on my 2022 Lt1 Camaro with 2300, TooHighPsi port injection w/Motiv Reflex controller, thpsi 10 rib pulley/tension system, Rotofab, E65 and made 707/662 on a bone stock Lt1, stock A10 and drivetrain, stock Lt1 fuel system, the only addition is JMS boost pump. Ran 9.86@142 on 10.5 lbs of boost. It's the ticket to go fast. Drive like an NA car or Stock Lt4 until you gotta get on it, great street manors. Thanks for posting Matt, great video.
11-24-2022, 08:05 PM | #5 |
Drives: ZL1 1LE Join Date: Apr 2022
Can you add these to basic bolt on zl1 and be able to run full e85? Does it require any pump upgrades to accomplish full e85?
If that's discussed somewhere can you post a link. I really want to run e85 without mixing and not spending 5k+ on a fuel system. |
11-24-2022, 08:25 PM | #6 |
The plates, plus injectors, controller, installation, tuning, & JMS voltage booster for the in tank pump means you’re at $5K anyway. But that’s still the best deal out there for fueling. A good set of DI injectors (+52/+65) are $5K by themselves…
11-24-2022, 08:39 PM | #7 | |
Around $3000 for plates, controller and jms booster, flex fuel sensor. Am i missing something? I need to tune the car regardless, so I don't really count that towards the fueling price. If I could do intake, headers, and the above mods to run full E85. That would be nice. Edit:. Forgot the injectors around a 1k...yep that's getting expensive. |
11-24-2022, 09:00 PM | #8 | |
11-25-2022, 07:55 AM | #9 |
Dyno Show Queen LOL
Any problems ever with transition?
Some hits might be perfect and some hits maybe a slight bog or hesitation on a Pull? But all in all perfect transition under acceleration? I mean the principal is the same as the ZR1 but certainly the the port and di injection computers communicate with each other better rather than just adding an aftermarket ecu that specifically running the port side. There must be hours and hours of tuning on where to bring in the injectors and at what rates and so on? care to explain to the people that don't have this setup? and the different types of ecu out there to do this?
11-25-2022, 08:05 AM | #10 | |
11-25-2022, 09:00 AM | #11 | |
11-25-2022, 09:19 AM | #12 | |
You will want to upgrade the low side with either an aux pump or bigger tank pumps(dual/triple) for full E85.
2016 NFG 1SS A8
11-25-2022, 12:24 PM | #13 |
With a tune, I’m sure you are right. But not from GM was my point. Which was crazy IMO.
11-25-2022, 01:12 PM | #14 |
Petro-sexual
Having seen stock cam cars get out to around 800-WHP, with just near-full-E', would a JMS hang in there, if there was no ambition, later, to go any further with mods? I literally mean no changes beyond intake, 2650 (with the stock 90mm pulley for around 15-16-psi), and literally nothing else on the motor.
