![]() Drives: ZLE Join Date: Aug 2022
ZLE possibly sitting through winter conditions
Is it worth taking delivery of a car that sits on an open lot during winter conditions?
Will there be any issues with rust since the Great Lakes are nearby? I read in a separate thread on here that they are not even covered. I live in Los Angeles and was able to get this car for a pretty good deal (5k markup). Regular ZL1s are going for a 10k markup. Was second in line and dealer was upfront and told me it would be at least a 6 month wait, but I was lucky enough to get the car allocated to me and built right away. The car was built 10/15. So it’s been sitting there for a month now. Dealer reached out to the factory yesterday and they said they are having logistics issues. The order was placed as sold so it will be marked hot (what does that mean?) and will be placed on the priority list. Any info/feedback would be helpful. |
![]() Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Hey there,
I personally wouldn’t worry about it, especially that it’s been built recently. I would however make sure to have your dealer inspect the 4 tires prior to you taking ownership. The ZLE tires will crack in very cold temperatures, in which case GM would have to replace them at their expense. Good luck, Geoff |
Thanks Geoff.
I’ll make sure to have them check the tires. |
![]() Drives: 2021 Crush ZLE Join Date: Mar 2009
Hot Ship will mean they will ship it ASAP. Just happened with my CTS V, they called and added it for Hot Ship, and it was here the next day. Im 300 miles from LGR. That should be a good thing for you.
Former GM Norwood Employee
2021 Crush ZLE 6spd 1-19-21 1100 1-27-21 3400 TPW 2-8-21 2-04-21 3800 Built 2-26-21. 4300 3-08-21 Delivered Last edited by Z28COP; 11-17-2022 at 12:15 AM. Reason: punctuation |
2020 Shadow Gray 2SS
As long as the car isn't driven on a salted road, I wouldn't worry about rust, if it simply gets snowed on, not an issue... It is the salt on the underbody that wreaks havoc on cars... (from someone who lived in Chicago for 43 years and worked in the Autobody industry growing up)...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
![]() ![]() ![]() Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Your ZLE needs to be trucked the entire way. No train. They need a full load headed your way before it will ship.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
#7 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I can’t imagine thinking $5000 ADM is a “good” deal. Eesh
These are made in Michigan, so they’re immediately subjected to whatever the weather is when they leave the factory and there’s nothing one can do to avoid that. This includes whatever weather the carrier ends up driving through. This has been the case for all Camaros since 1993 when production moved to Canada through 2015. “It is what it is” - I’d be more concerned with paying ADM than I would the weather conditions.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I agree that on delivery they and you need to carefully inspect the tires. It's the cold yes but also, worse, is being driven in the cold, it's the flexing of the rubber on the road. Otherwise I think you're safe. Also look at the manuf date codes on the tires to see if they're "new".
#9 |
Thank you guys! This was all very helpful!
