Old 11-15-2022, 09:24 PM   #1
Vxpor
Drives: 17 Camaro 2SS; 18 Camaro ZL1
ZL1 A10 — Transmission Whine? Jerk/Clunk?
First thread here, I would like some advice from you folks.
Recently, I’ve been experiencing a weird whine/hum coming near the engine bay — it is noticeable upon gradual acceleration.
In addition, I’ve been experiencing light jerking towards the higher speeds — during both upshifts and downshifts going 50+ mph. Most notably, the car jerks violently from 6th to 5th gear every single time when I manually downshift. Same occurs when you put the car from reverse to drive.
Any ideas on what I could be dealing with? I believe I need new motor/transmission mounts. In terms of the whine/hum it may be deriving from the torque converter; ZL1 is currently at the dealer and I expect to hear back from them by Thursday.
Videos emphasizing the symptoms:
Video 1 — Whine & Jerk:
https://youtube.com/shorts/CfPKvP_BNYc?feature=share
Video 2 — Emphasis on whine during light acceleration: https://youtube.com/shorts/9xhAy20uwSo?feature=share
Vxpor is offline   Reply With Quote
Old 11-15-2022, 09:39 PM   #2
SATINSTEEL1LE
Drives: 21 ZL1
Whine is normal. My 18 Z and now my 21 Z both do it.
As for the clunk. My advice would be disconnect the battery for a day and let the trans adaptives reset.
Or if you had a tune/trans tune I'd have someone look at the TCM tune and see if they set the pressures too high.
SATINSTEEL1LE is offline   Reply With Quote
Old 11-16-2022, 12:45 AM   #3
Vxpor
Cool. Thanks for the message. I’ll give this a shot once I get my Camaro back.
Old 11-16-2022, 06:47 AM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
That P to D shift sounds awful but it's hard to tell on a laptop what the issue could be. If you still have some powertrain warranty on the car I'd take it in.
Old 11-16-2022, 07:09 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
R to D clunk is not normal.
The rest looks and sounds normal.
Old 11-16-2022, 07:50 AM   #6
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
Oh and if its your torque converter… per the service manager… waiting on a 3rd converter to go in my trans because the first 2 showed up useless. Without saying it he agreed the reman standard from GM is not there. They don’t care about the warranty parts they give us.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 11-16-2022, 07:56 AM   #7
BlancoPopular
Drives: 2019 ZL1
So last week i was on the dyno and the car was fine. After the last pass they asked me to move the car off the dyno, it felt a little rought shifting out of park which it has never done before , move the car a few feet and one of the techs tell me my car is leaking trans fluid. Get the car on the lift and the outputshaft pushed itself out a bit and the outputshaft seal came off and the bushing that holds the shaft in was also pushed out causing the fluid to leak. I did some research and nobody else has seen to have had this issue, it may be worth looking at the output shaft area to see if anything has moved.
BlancoPopular is offline   Reply With Quote
Old 11-16-2022, 08:31 AM   #8
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
Something similar?
I have a 2022 ZL1 with 2400 miles and have noticed a few times when approaching a driveway with a slope I hit it at an angle to avoid rubbing the front and when slowing down and creeping up it I give it gas and it feels like neutral then bang it grabs?
Only time it does this is on an angled slant like this?
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 11-16-2022, 08:55 AM   #9
BlancoPopular
Drives: 2019 ZL1
Originally Posted by FRANK121 View Post
Something similar?
That’s usually the rear wheels coming off the ground , chassis is stiff.
Old 11-16-2022, 09:47 AM   #10
clg82
Drives: 2020 Camaro ZL1
Something similar?
I noticed the same thing as well, we have really stiff chassis and sometimes the e-dif doesn't like those types of inclines. To reduce this I put mine in snow/ice mode before entering and leaving and it helps.
Old 11-16-2022, 03:16 PM   #11
Vxpor
Thank you all for your answers — I will take all feedback into consideration. As of now, the dealership told me the transmission may be defective. Luckily, I have GM’s Powertrain warranty. In addition, the dealership is going to thoroughly inspect all components to give me a final answer by tomorrow.
Also my ZL1 is almost fully stock as I installed a Borla ATAK Catback and a Rotofab CAI; no tune.
Old 11-16-2022, 03:33 PM   #12
PKG4U
Drives: 2018 ZL1
Uh, if you are to acquire a “new” transmission I would love for you to report it back as soon as you can. I’ve been waiting 3 months for them to “rebuild” my transmission, not a new one, because GM insists they have 0. I’m under power train until 2028 or 120k miles but that didn’t seem to affect my situation any. Good luck
Old 11-16-2022, 03:54 PM   #13
Vxpor
Wow 3 months! I’ll definitely make sure to report it back to you on what they tell me — I hope it isn’t a transmission issue lol. Hopefully your transmission is rebuilt soon. That already sucks having to wait that long.
Old 11-16-2022, 03:57 PM   #14
PKG4U
Drives: 2018 ZL1
3rd torque converter came in this morning waiting on a call any minute. Thanks brother. I pray yours is fine
