Old 11-13-2022, 07:11 PM   #1
holdinslab
holdinslab's Avatar
Drives: SSCamaro 2016 m6
idle surge with Procharger & Cam
Anybody have the secret sauce to getting a Procharger and cam combo to idle decent without to much rpm surge. I have tired rescaling the airmass tables and maf to reduce the torque commanded but it seems to be good one day and back to the same surge the next.
Car has Btr Blower cam, p1sc1 Procharger 10lbs, lt2 intake baro breakout, headers, full bust bottom end, monster clutch triple disc clutch m6... working with hptuners
holdinslab is offline   Reply With Quote
Old 11-13-2022, 08:43 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Needs a tune by someone who knows what they’re doing. A cammed Gen5 LT engine is a tough one to learn on. MAF is just the tip of the iceberg, VVE and VT tuning is critical to getting a cammed LT to idle and drive well.
Old 11-13-2022, 09:53 PM   #3
JimGnitecki
Drives: Chevrolet Camaro LT1
That was SO politely said! And hopefully he will listen.
Jim G
JimGnitecki is offline   Reply With Quote
Old 11-14-2022, 11:09 AM   #4
holdinslab
holdinslab's Avatar
I built the car myself , just not much of a tuner. trying to learn. that's the only way right? thanks for the help though.
Old 11-14-2022, 11:26 AM   #5
Joshinator99
Moderator
This is a very tough platform to learn to tune on. Watch Greg Banish’s Calibrated Success videos if you want to try to understand this better.
Old 11-14-2022, 11:55 AM   #6
LT1ornothing
Drives: 2020 LT1 M6
Agreed with the other guys, let a good LT tuner take care of the tune. You got Jeremy Formato and Howard Tanner relatively local to you.
[SBE] ECS NOVI 1500 supercharger, 2" Longtube headers, flex fuel, LT4 injectors, LT4 HPFP, baro breakout
Tune date and results to be determined
Old 11-14-2022, 12:44 PM   #7
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Great advice.
Old 11-14-2022, 12:59 PM   #8
JimGnitecki
holdinslab: You can do serious harm to your engine "learning" how to tune. Worth the risk?
Jim G
Old 11-14-2022, 02:22 PM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
VTT and VVE more then likely need work.
Old 11-15-2022, 07:18 AM   #10
cjperformance
cjperformance's Avatar
Being a learner myself, my suggestion would be to get a "base tune" from a remote tuner, and finish dialing it in yourself.
The base tune will get you in the ballpark, then you can make incremental changes yourself and see how things respond.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 11-15-2022, 03:24 PM   #11
KingLT1
KingLT1's Avatar
^That's the only way to go. It's how I started. It all comes down to putting in the time and effort to learn this stuff.
Old 11-16-2022, 09:11 AM   #12
holdinslab
holdinslab's Avatar
I have gotten a base tune from a well established tuner already. I have recently moved to a different part of the country and the car is acting funky on cold starts. VVT goodies have been deleted on the car and I'm not completely lost, just trying to get some thoughts from others.
Old 11-16-2022, 09:28 AM   #13
KingLT1
KingLT1's Avatar
Maf is used for fueling not torque control. The Virtual torque tables are referenced for torque modeling and controls idle spark. Need to be logging spark and see what it's doing at idle.
Basically, you need to fail the maf, tune vve, turn maf back on, tune maf, then get the torque modeling correct in order to get sufficient idle spark. Then if it still surges you likely have something else going on.
Goat rope garage has some fairly decent YT videos on MAF, VVE, and VVT tuning for Gen 5 LT.
*If I had to guess, your base tune might have the minimum spark table cranked way up to get the idle spark in range and it's fighting the torque tables which will cause the engine to surge. The is common LS tune methodology that doesn't work on LT engines. I never raise minimum spark higher then 4-5 degrees in the 4-800colums and that is only so the trans shifts with more timing. Again, the proper way to get correct idle spark is go into the Virtual torque tables and pull torque in the idle areas for the timing tables up to 10 degrees only... pulling torque will increase timing. Adding torque will reduce timing.
Old 11-16-2022, 09:54 AM   #14
JimGnitecki
That was nice of you, KingLT1.
Jim G
