![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Snap, crackle, pop!
Discovered something interesting...
So my car is flex fuel tuned for E85. It seems when I run E85, no snap crackle pop. I've since switched back to 93 pump for the winter, and suddenly snap crackle pop cereal all over the place!
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
Just a guess, but maybe the flex fuel spark tables command an advance delta with high ethanol that reduces the pop/crackle effect of the minimum final spark table.
#3 | |
Hot Camaro
Thank you Al Oppenheiser!
Tuner probably was all about business and not bothered to waste time figuring out twenty-three dimensions worth of spark table playtoy stuff.
Drives: Camaro SS 1LE Join Date: Aug 2018
Every tuned Camaro that I have seen loses that with E 85.
#7 |
Great! Now in english?
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 6th gen Join Date: Aug 2013
Look at the flex fuel truck E timing map for the top four rows, it’s negative values My car sounds the same on E as 93. It’s doable
#9 | |
I've never been a nerd of the snap crack pops anyways. I don't think it sounds good unlike some people lol To me it sounds like the car is mis-tuned.
#10 | |
Hot Camaro
#11 | |
Drives: 21 ZL1 Join Date: Feb 2022
Meanwhile on planet earth whats pictured below is the portion of your factory tune where the burbles, pops and bangs are setup and managed. And can be enabled or disabled with those values as you(your tuner) sees fit. |
#12 | |
Hot Camaro
The tune from the factory is purposely done to push extra fuel into the system so that on deceleration it causes the system to burn it off and make these sounds. The only way to remove the tune that causes these sounds is to tune the engine to "run correctly." "Mis-tuned" and "running correctly" are not things that are explicitly defined with specific parameters and should be seen as generalizations - hence why I have quoted them. The sounds being generated are on purpose, from the manufacturer, and will constitute a proper tune according to what they intended to achieve. |
#13 | |
Here's a great video also showing how to setup a burble tune.
#14 | |
