Old 11-07-2022, 09:01 PM   #1
stormtrooperSS1le
Drives: 2017 camaro ss 1le
P0801 reverse inhibitor
Anyone ever replace this sensor?
How hard is it?
stormtrooperSS1le is offline   Reply With Quote
Old 11-07-2022, 09:23 PM   #2
stormtrooperSS1le
ACDELCO 54949hj part for 2010-2015 Camaro ss zl1 with the tr6060.
I am assuming these are interchangeable?
Old 11-08-2022, 08:48 AM   #3
stormtrooperSS1le
Anyone?!
There has to be someone who has had this issue.
Old 11-08-2022, 07:36 PM   #4
stormtrooperSS1le
There has to be someone out there that can help with this?
Old 11-08-2022, 09:46 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
1st time I recall someone posting about this issue.
Looks like you can do this without too much trouble:
Old 11-08-2022, 10:06 PM   #6
Gunkk
Gunkk's Avatar
But then again with your scorched wiring issues, you're going to be better off troubleshooting the harness before firing the parts cannon. That lockout solenoid circuit has 12V battery power all the time according to my manual, plus a sensing circuit, so at least 3 wires to look after.
On the other hand, I guess it's easy enough to do a part swap and see if the problem goes with it.
Old 11-09-2022, 01:33 AM   #7
stormtrooperSS1le
Bro life saver, I found a solenoid on eBay for 95$. It it’s for. 10-15 I’m assuming it’s the same however since the trans is the same.
Would you agree? I’ll get under there and check out the wiring first. I’m hoping it’s not more burned wires. Not sure where this harness runs to, but I’ll try and find where it leads.
Old 11-09-2022, 01:38 AM   #8
stormtrooperSS1le
Here is my codes list, some are just emissions stuff but the reverse inhibitor is right there.
The hvac I have squared away.
Have a stabilitrak light I can’t seem to get a code on either with hptuner.
