Just did an Ooops
Wife just filled up our ZL1 with 87 octane
![]() Actually was 5.1 gallons but wonder what I need to do? Reading the post on octane booster turning plugs orange I'm not sure about using any? Being that the rest of the tank was already 93 maybe the 5 gallons of 87 won't hurt that much? Any suggestions other than don't let the Wife go get gas ![]() Stock car with axle back exhaust and CAI.
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
If you fill 5 gals of 87 and 14 gals of 93, you'll end up with 91.4 octane which is better than what I get at the pump here. I would fill the rest of the tank w/ 93, run it down a few gals, then add more 93, and so on.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
+1, It'll be fine.
You let your wife drive your car?!
Whatsamatterwitu?! |
The 5.1 gallons topped it off so the rest is 93.
And Happy Wife = Happy life
2022 Black ZL1
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
91 octane is terrible for these cars. Even in stock form you'll get knock. Us poor bastards in California get hosed with fuel selections because all we have available is 91 octane. Guaranteed knock is a factor with anything less than 93, however.
Drive her nice and easy, don't get on it too much and then once you have burnt some of the fuel that is in that tank, refill it and you should be good to go.
758 HP/ 804 TQ |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
No harm done. It will perform as usual.
#8 |
![]() Drives: Zl1 1le Join Date: Apr 2018
The ECU will adjust to the fuel rating, but to be on the safe side I would take it easy until this tank is empty.
#9 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
It will be fine. As others said just top it off with high octane. I have friends that refuse to use 93 and put 87 in there cars and have no issues at all.
