11-03-2022, 11:30 AM | #1 |
Drives: 22 ZL1 Join Date: May 2022
TVS 3100 will it fit?
New blower 3100
https://www.lsxmag.com/features/sema...-supercharger/
2022 ZL1 M6
11-03-2022, 11:39 AM | #2 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I'm confident now that Eaton has released the rotor pack that applications will soon follow for the popular models. Now, whether or not there will be a justifiable delta over their 2650 model remains to be seen but, I can guarantee testing will ensue. Especially since their previous attempt at this rotor pack size was not a success.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
11-03-2022, 12:08 PM | #3 |
Drives: 21 ZL1 Join Date: Feb 2022
Im running into fueling issues with the 2650 as it is. That is really going to push a stock fuel system overboard.
11-03-2022, 12:31 PM | #4 |
Drives: 2017 ZL1 Join Date: Jan 2017
I'm one of the guys running TVS2300 and have been waiting for this! Agree with the fuel situation but hoping that it could be run in very efficient state on the stock fuel system plus the 50/50 meth/water I run.
11-03-2022, 12:48 PM | #5 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
With the bigger rotor packs, what's going to happen on the cooling side? We only have so much room under the hood.
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
11-03-2022, 01:03 PM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I'm sure this blower has been well thought out but a bigger blower is not always better if you can't use it within its efficiency range. Hellcats had this issue with the 4.5L Whipple blower, it barely outperformed the stock 2.4L and 2.7L blowers and it generated a ton of heat doing it because in order for it to perform at its best, it needed a LOT of boost pushed through it.
11-03-2022, 04:55 PM | #7 | |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Apparently the TVS2650's require high revving in order to make the boost they need to make power on these engines already. I don't know who would in their right mind move up to a TVS3100. Bigger isn't always better people.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
11-03-2022, 05:21 PM | #8 |
I think there are 3 threads now on the 3100, if Magnuson is using the 2650 case as I'm sure they are since I've seen some videos of Magnuson testing the Jack Shaft and our under-hood version then you'll have no problem fitting the 3100 on any of the Gen6 Lt1 or Lt4 platforms. Just hold on till after Sema and you'll probably see some announcements. With the back logs of 2650s at 18 to 20 weeks don't expect it real soon. The 2650 may still be a better application for most Lt1s or even Lt4s depending on the mods. The 3100 may be more beneficial to the bigger inch motors with ported heads, cam and headers.
11-04-2022, 09:58 AM | #9 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Did the 2300's price drop when the 2650 came out?
11-04-2022, 09:59 AM | #10 |
Are they even making them anymore? I know when I bought a 2300 for my Z06, Magnuson had already discontinued that blower.
2018 Audi TT ▊RS
11-04-2022, 11:58 AM | #11 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
I will definitely try because the 2650 is going to be out of steam soon.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
11-04-2022, 12:17 PM | #12 | |
@zle_blackwing
The point was, was it discounted at that point since it was discontinued due to the emergence of the 2650? Hence will the 2650 be discounted with the emergence of the 3100?
11-04-2022, 12:24 PM | #13 |
11-04-2022, 12:29 PM | #14 |
If you read Eaton's description of the rotors, it's obvious they are targeting the aftermarket specifically, versus the 2650 where they sold it to auto manufacturers.
I honestly don't expect them to discontinue the 2650 as it will suit 99%+ of people. To fully utilize the 2650 you already need to build the engine and fully build the fuel system with port injection. The only thing that has made me doubt that theory is looking at the pricing listed on Harrop's site. Granted, it's in AUS, there is less than a $1k difference between their 2650 and 3100 offerings for our car. If I was buying something, I certainly wouldn't get the lesser of the two for that small of a difference.
