![]() Drives: 2023 VOM Camaro 2SS Coupe Join Date: Oct 2022
Underbody materials
Hello everyone. I am new to these forums and tried to search for this answer but could not find what I was looking for...I may just not be searching properly.
Anyways, what materials are used for the underbody panels? Is it a composite material that is resistant to corrosion from salt and water, or is it a metal that is susceptible to corrosion? If the latter type of material is used, is there a coating or cover that people like to apply to the panels to help resist corrosion? Thanks in advance for the help! |
![]() Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
According to the manual underbody components are coated with an anti corrosion material. They recommend spraying with clean water every six months to remove corrosive elements but state not to use cleaners as that could remove the anti corrosion coating. We’ll see how well it works.
I know Ford is awful with this as my 2017 mustang rusted quite a lot on the underside. There was no mention of anti corrosion in that manual if that says something. |
#3 | |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Maybe the video will help
![]() ![]() ![]() Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
That’s the Gen 5 that was built in Canada. Probably a little different process than the Gen 6 built in Lansing. It is an interesting video!
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
There is a similar, 44-minute video about the 6th gen from 2017, but I don't recall it discussing the underbody or coatings specifically. The video itself is a concatenated set of episodes in the "Supercar, Superbuild" series, and had been viewable on youtube until a 2 or 3 years ago, someone must have complained and it got pulled.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 10-31-2022 at 06:45 PM. |
![]() Drives: 2021 SS 1LE SHOCK Join Date: Mar 2021
Car companies have been zinc dipping (galvanize) for years. I know they used to wax dip truck frames. They also squeeze sealant on certain areas.
However unless you are driving a Delorean, any nicks, scratches, and trapped corrosive materials will cause rust. Best prevention is to do regular under body washes and paint any deep nicks. |
#7 | |
Moderator
#8 |
![]() ![]() Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
all cars rust underneath imho. you want it to stay nice avoid winter driving.
#9 |
Thanks for the information everyone. I understand it would be ideal to not drive it in winter/bad weather to avoid the salt, but my situation does not really allow for a second car right now (mostly due to space).
For some context, I am deciding between a camaro and a corvette and read that the corvette under body has composite body panels that are resistant to corrosion so I figured I would find out if the camaro under body was similar. P.S. I know many of you are probably cringing at the thought of either a camaro or corvette being driven in snow, but I would rather have a sports car and drive it year round than not at all. |
#10 | |
It's definitely not as bad as a car from the 90s or early 2000s, the underbody is protected, but wherever the coating got damaged from road debris, rust has started on the frame.
#11 |
![]() Drives: 2022 Camaro ZL1 Join Date: Dec 2021
If you're concerned about the underside, you might look into getting an Underwasher. I use mine after one of our cars has been through snow or mud, and for at home use, it's pretty effective.
https://www.theunderwasher.com/
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2018 Porsche 718 Cayman GTS 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2024 Honda Civic Touring 1971 Datsun 240Z |
