Old 10-29-2022, 01:16 PM   #1
JP374
JP374's Avatar
Drives: 21 Lt1
Toohighpsi port kit ?’s
Hey guys, so I’m looking at the THP port kits and am curious if I put this on with my current tune and do the MAF adjustment like the tutorial shows won’t my VTT and DD tables be out of whack too? It’s my understanding that most everything on these cars is MAF controlled. I’m really looking at adding the PI kit but just got the car dialed in and running awesome on e50. Yes I’d like to be able to not blend and have the extra fuel if I add more boost down the road.
Currently running BTR stage 2 cam, LPE big bore, +30’s with P1X 14psi at 891 whp on e50/55 @ .84 lamda and 5.2MS. @ 6800 rpm.
It took me awhile to get my daily driving and wot dialed in to my liking I just don’t want it to go out the window with the PI kit
Thanks guys
JP374 is offline   Reply With Quote
Old 10-30-2022, 09:22 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I am sure it will require some tuning work outside of just yanking 30% out of the MAF table from 6500hz on up. If this shit was easy everybody would be doing it. I would stay at home base and enjoy the car for a while if you have it dialed in. Blending E is easy as pie anyway.
Old 10-30-2022, 09:28 AM   #3
JP374
JP374's Avatar
Drives: 21 Lt1
Thx King.
Kinda what I’m thinking as well. I’m happy at my current power level and drivability, it would be solely for the ease of pump e85 at this point and to have added headroom down the road. Maybe I will focus on other things like suspension etc.
Old 10-30-2022, 10:50 AM   #4
KingLT1
KingLT1's Avatar
Originally Posted by JP374 View Post
Thx King.
Trust me I have been thinking the same thing, but I just upgraded the injectors this spring and don't want to spend a bunch of time re-tuning.
If I had the PI kit then I could likely buy Josh's 8" lower off him and see how far I can push this thing before the pistons end up in chunks. Lol
There is that little Devil dancing on my shoulder again! We all suffer from it!!
Old 10-30-2022, 11:36 AM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Do it ya softie!
Old 10-30-2022, 11:39 AM   #6
JP374
JP374's Avatar
Drives: 21 Lt1
Yep that devil whispering in our ears saying NEED MORE POWER!!! Lmao
Old 10-30-2022, 11:48 AM   #7
laynlo15
Drives: 2022 Lt1 A10
Thanks guys
I'm running it on my 22 Lt1 with 2300, matter a fact I was the first on down the track with this setup at the Ls Fest. Mike (toohighpsi) flew in to tune my car and it does require tuning for sure. There are a several tuners that are already tuning for others with the Reflex controller. Matt at Nickey Performance has done several Zl1s, Phil@phdtuning has four he's tuning and Alex at New Era made over a 1000 rwhp with the stock Lt1 HPFP and Injectors plus different in tank pump or pumps, just not sure how many or who's he was using. Now he didn't do this with a stock Lt1, it had cam, heads, rods and pistons on E85 and 2650 Maggie. Mine is about 69 % DI fueling and 31 % port. So, it depends on your abilities to tune beyond the DI system. He's selling all the kits he can make so lots are buying them and learning to tune with them.
Old 10-30-2022, 02:04 PM   #8
JP374
JP374's Avatar
Drives: 21 Lt1
I appreciate the info. Those guys you mention do remote tunes by any chance?
Old 10-30-2022, 03:22 PM   #9
laynlo15
I know Phil does, he tuned my C7 and initially tuned my new Camaro. I see you have a Pro Charger and I know he does a lot of those. Sounds like you already have HPTs so that's what you'd need. I don't know about Alex at New Era but I think Matt at Nickey does. You'd just have to contact them.
Old 10-30-2022, 04:35 PM   #10
JP374
JP374's Avatar
Drives: 21 Lt1
Ok if I decide to go that route I will look into them, thanks
Old 11-08-2022, 11:55 PM   #11
toohighpsi
Drives: 2015 C7 Z06 M7
With only 30% port, it's pretty much just that easy, each tuner I know has their own way to deal with the tune and manage the torque aspect of it (as there's many different suitable options) but at that low level, it's really quite easy.
On Greg's car the work that Phil did on his E85 tune had it already well prepared for port injection, I honestly didn't have to do anything torque related to his car to have an adequate reported torque.
Once you're at 1000+ RWHP with a stock LT1 high side on full E (80%) you'll need about 65% port and that requires a good understanding handling the torque tables to achieve the required torque to keep the automatic transmission happy (manuals are easy).
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
Old 11-09-2022, 12:10 AM   #12
toohighpsi
Thanks guys
Are you running meth also? Adding about 10% port is all you'd need to be able to run full E with your current fuel system. Going to 30% would give you enough to hit just over 1k on full E.
Mike
www.toohighpsi.com
2021 Porsche GT4 M6
2023 Corvette Z51
Old 11-09-2022, 04:50 AM   #13
JP374
JP374's Avatar
Drives: 21 Lt1
No meth. I’m currently running e55. I’m happy at current power level at the moment. Would be nice to not blend etc. then of course be able to pulley down or add bigger blower.
Thanks for the info
Old 11-09-2022, 10:23 AM   #14
laynlo15
Thanks for the info
It really is, luckily our area never has over E70 and its usually E65 to E67 from the pump. Every time I fill up I log the E content and its consistent between the E65 and E67 so it makes it easier to tune at the content for FF advance and overall tuning.
