Old 10-24-2022, 04:05 PM   #1
pisters
Drives: Camaro 2SS 2017 and Camaro 2021 2.0
How reset TCM (transmission control module) ?
As some of you may know, I have a 2021 Camaro 2.0 Turbo A8 just 11k miles
that out of nowhere started clunky/harsh 3 > 2 shift. Even though the car is almost new I have no warranty because it was imported to my country. I am alone in this.
I read that reprogramming or resetting the TCM can help to solve, how can I do this? The only option is to pay a fortune for the HP Tuners? I just want to reset to see if my transmission is back to normal.
I have not been doing well for a few months now and I am selling my stuff, and this just happens to me. I want to fix the fault to try to sell the car so I can stay alive. Thanks
pisters is offline   Reply With Quote
Old 10-24-2022, 04:51 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Maybe disconnecting the negative battery cable from the battery and leave it disconnected for a few hours to reset the car’s computers would help.
Old 10-24-2022, 07:06 PM   #3
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Take it to a chevy dealer and have them perform a transmission re-learn.
lt4camaro is offline   Reply With Quote
Old 10-24-2022, 07:10 PM   #4
SATINSTEEL1LE
Drives: 21 ZL1
Lol pull battery cable for a while...
SATINSTEEL1LE is offline   Reply With Quote
Old 10-24-2022, 07:20 PM   #5
pisters
I dont have dealer. I said, Im alone with this problem because my car dont have any warranty because its imported. Local shops its my option but in my country are useless and very expensives with Camaro
Old 10-25-2022, 12:57 PM   #6
pisters
Old 10-25-2022, 04:13 PM   #7
easttxss
easttxss's Avatar
Drives: '16 2SS M6
You will have to order a j2534 pass thru device and sign up with GM's aftermarket Techline so that you can program the module. It's $45 USD for one vehicle, for 2 years. https://www.acdelcotds.com/subscriptions#
Be cautious of the device you buy, there are a lot of cheap Chinese knock-offs out there. The legit ones are fairly pricy at about $1500 USD.
This doesn't really sound like an option for you, so your best bet is to take it to a well established, independent shop that has the necessary equipment to do this, or sell it as is.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 10-25-2022, 05:35 PM   #8
I can't think of a better option than these:
a) buy a scan tool that can set GM transmissions to relearn mode, here's an example: https://www.amazon.com/gp/product/B097R8Q122
b) if that simple "fix" doesn't help, bite the bullet and take a road trip to San Antonio or even Houston, TX, find a proper speed shop and get this thing fixed
c) optionally, longer term you can buy a HP Tuners MPVI3 device with credits and learn how to tune your car
Option a) is super useful as a bare minimum to those that have no easy access to service capability, because this means you're on your own and you can't fix anything without proper tools—expecting that nothing will ever go bad with a mass produced car is unrealistic.
Old 10-26-2022, 08:17 AM   #9
easttxss
easttxss's Avatar
Drives: '16 2SS M6
If my map is correct, he lives in Paraguay
David
'83 Jeep Wagoneer
Old 10-26-2022, 11:01 AM   #10
bdavies11
I posted in the other thread but...
Try this because it may not be the transmission. Have your mechanic check for a loose axle nut. I had the same issue where it was clunking on downshifts and thought it was the transmission. Was just a loose axle nut clanging on certain downshifts.
bdavies11 is offline   Reply With Quote
8 speed, automatic, issue
