Old 10-21-2022, 05:18 PM   #1
ACESHI
Drives: 2023 Camaro 2SS convertible
Top protection
Any suggestions on the best fabric top products? I just picked up my 23 2 SS and want to get top protected
ACESHI is offline   Reply With Quote
Old 10-21-2022, 06:05 PM   #2
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
I used RaggTopp on my Corvette convertibles with good luck. I haven't done anything with this one. I have a fabric lint brush that I use to brush it but it's going to be stored inside and used in fair weather so I don't feel I need it.
You can look at Autogeek and they have a revire/how to video on the site.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black
Jus Cruisin is offline   Reply With Quote
Old 10-21-2022, 06:18 PM   #3
Newcastle
Drives: 2022 2 SS 1LE on order ....now a 23
303 Aerospace has a good soft top conditioner.
Newcastle is offline   Reply With Quote
Old 10-21-2022, 06:41 PM   #4
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I use Chemical Guys convertible cleaner kit.
nancygrl is offline   Reply With Quote
Old 10-21-2022, 06:54 PM   #5
Jus Cruisin
Old Gearhead
With a few convertibles on here with rubber/glue bleed through, I'm not sure I would use a cleaner on the top. Just a fabric water repellant.
Old 10-22-2022, 10:23 AM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
303 Fabric Guard.
Links, directions, and pictures of it still performing after 4-1/2 years are here: https://www.camaro6.com/forums/showt...2#post11092912
Old 10-22-2022, 04:06 PM   #7
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
+1 on Gunkk's original post. I followed it, worked great.
Might sound like it might take a long time, but by using the roller there's very little chance of dripping anything where it shouldn't get to.
Also, since you're standing up the whole time, I swear it feels like *less* of a PITA than hand-cleaning the brake dust off the wheels. (Nope, haven't switched to the Powerstop pads yet.)
You can usually find the two-bottle kit for a very reasonable price on either Amazon (or maybe Walmart); IIRC I pretty much used up one whole bottle, but only about half of the other, so next time I might just buy a single of the one I used, and empty out the half-full one in the process.
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
Old 10-23-2022, 08:39 AM   #8
nancygrl
雪の玉
nancygrl's Avatar
I taped off the rear window and only used it on the big areas for an initial cleaning. From this point on I'll only be using the protectant to seal and repel.
Old 10-24-2022, 04:14 PM   #9
MANNAXMAN
MANNAXMAN's Avatar
How do you plan to clean things like bird droppings? Just water?
As a "victim" of this convertible top issue, I'm not convinced the cleaners are the cause. I've used both Raggtopp and 303 Aerospace cleaners on my top since new. If the cleaners were a major cause for whatever is happening to my top, I would expect my entire top be affected, not just various spots on the driver's side.
These are old pics. Most, if not all, of the spots have grown in size, and there are probably some new spots.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 10-24-2022, 04:28 PM   #10
Jus Cruisin
Old Gearhead
Soap and water. With RaggTopp, it should rinse off. That's what I do with my boat, too.
Old 10-25-2022, 08:13 AM   #11
Gunkk
Gunkk's Avatar
Brush off the chunks and loose stuff. Spot clean with soap and water.
Best thing about the 303/Ragtop is that the fabric is sealed so the "wet" bits don't really get into the top's fibers too much before they dry. Dirt, dust, pollen blobs, bird droppings mostly just wipe off with a dry paper towel or come off with the cheapo sticky-peel-off lint roller.
Old 10-25-2022, 10:17 PM   #12
W-Scott
Drives: 2023 Camaro LT1, Convertible M6 sp
303 Fabric Guard.
That looks really good!!! Couple questions about the mini roller application method you used.
Did you spray it on to the roller or pour it in the tray like paint?
How heavy/thick/thin did you put it on the top?
The bottle talks about direct sunlight?
Just asking because how ever you did the roller application seems to have worked great!
W-Scott is offline   Reply With Quote
Old 10-26-2022, 09:11 AM   #13
joekd
Drives: 2018 Camaro SS vert
I clean with regular car wash and a brush then apply chemical guys top protectant
joekd is offline   Reply With Quote
Old 10-27-2022, 12:41 AM   #14
Gunkk
Gunkk's Avatar
I did all of this in my garage, sunlight wasn't an issue.
Keep a clean MF rag or two handy for the inevitable drips. You DO NOT want this stuff drying on the paint or glass or anything. It's like clear coat. But you want it soaked into the fabric, not sprayed all over the place, so...
1. Unscrew and remove the spray nozzle, throw it in the trash and never touch it again.
2. Pour 1/4 of the bottle 303 into the paint roller pan.
3. Use the roller like you are painting. If you've ever painted with a roller, you know. If you haven't, watch a video Slow and steady with light pressure. You want it to wet the fabric enough to soak in (and it will) but not drip.
4. Do half the top (I did driver side first).
5. Pour another 1/4 of the bottle in the tray.
6. Do the other side while it dries.
7. 3rd quarter of the bottle for coat #2 on the first side. It'll still be very slightly tacky, and that's OK.
8. Remaining 25% for second coat on the second side.
One full bottle did two complete coats.
