Old 10-19-2022, 08:08 PM   #1
Skyset
Drives: 2017 Camaro 2SS Coupe
Is this a fair price for a repair?
Hi there,
I just want to check something…appears my camaro is leaking a bit of oil, and I took it to a shop and the mechanic showed me it’s coming from the oil pan (in atleast 2 different places, around bolts too)
The mechanic said me he needs to re-seal the pan, and it’s 8-10 hours labour, around $1200 CAD (~$900 USD) Does this seem right to you?
Thanks!
Skyset is offline   Reply With Quote
Old 10-19-2022, 08:13 PM   #2
757Fixer
757Fixer's Avatar
Drives: 2022 1SS 1LE M6
That sounds extremely pricy to me. Could they not drop the pan an inch or two, clean everything up and re-install, or do they need to jack the engine?
2022 1SS 1LE M6 ordered 31 Jan 22
Picked up 20 Aug 22
757Fixer is offline   Reply With Quote
Old 10-19-2022, 11:15 PM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
In most modern cars there's dropping of the sub-frame involved. Sounds pretty normal to me.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 10-19-2022, 11:54 PM   #4
AZIROC
Drives: '86 IROC-Z '18 ZL1
For that price. I'd be 100% with a shop doing it. For the pan gasket u have to either lift the engine up or drop the subframe.
Old 10-20-2022, 06:26 AM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Sounds reasonable to me knowing the labor involved to do the job.
Old 10-20-2022, 06:33 AM   #6
cjperformance
cjperformance's Avatar
Theres a known issue with oil pan bolts not being torqued correctly from the factory. You might be able to fix it yourself by just torqing the oil pan bolts. Had this issue on mine. Fixed it in 5 min after it was up on stands. No leaks since.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 10-20-2022, 06:52 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I just tightened mine while under the car for a regular oil change but I have that capability and maybe you do not but in most cases we've seen with this problem your mechanic is overdoing it. With mine the bolts took about a half turn and it never leaked again.
Old 10-20-2022, 07:28 AM   #8
Skyset
Thanks for all the responses. I think first I’m going to try and get under it, and inspect the oil pan bolts myself.
Old 10-20-2022, 08:22 AM   #9
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I agree that you should check this yourself first. There have been multiple reports on the forum of people finding the bolts loose. Good luck and I hope that's all it is for you.
476 rwhp/440 rwtq (sold)
Old 10-20-2022, 09:03 AM   #10
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Loose pan bolts is a known issue. 9/10 you can just tighten them.
Old 10-20-2022, 12:47 PM   #11
FarmerFran
FarmerFran's Avatar
Get the torque spec first
<Insert Cars You Own Here>
