Old 10-18-2022, 06:12 PM   #1
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
HEADACHE! I'm totally confused
2017 Camaro 2LT RS Convertible, Chevy OEM wheels 20"x8.5" 25mm Offset front and rear.
I've tried searching and reading, but my headache get's worse as my confusion grows.
I need new tires and wheels, scraped too many curbs. The last time that I bought wheels was 45 years ago, I'm 66. Now I see offset -, offset +, 8.5", 9" 9.5", 10".
The tires that I want BGOODRICH G-FORCE COMP-2 A/S PLUS, Front & Rear 245/40ZR20 Ultra High Performance All-Season or CONTINENTAL EXTREMECONTACT DWS 06 PLUS, Front & Rear 245/40ZR20 Ultra High Performance All-Season.
I'm retired on a fixed income so wheels will be rotated so the tires last longer.
What size wheels can/should I buy without having to worry about whether those tires will fit and there won't be an issue with my car.
Glenn
SOLD - 2017 Camaro 2LT RS Convertible
2017 GMC Arcadia Denali
truckrglenn is offline   Reply With Quote
Old 10-18-2022, 07:38 PM   #2
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Buy:
- 20" wheels
- 8.5" width
- ET25 offset
Same diameter, width & offset as your stock wheels and will fit either of those 245/40/20 tire options.
YouTube
Old 10-18-2022, 08:09 PM   #3
truckrglenn
Thanks, I haven't seen any aftermarket wheels with 25 offset. How far in either direction can the offset be, or does it have to be 25mm? That's where a lot of my confusion comes from.
When I go to sites like Tirerack and put my Camaro 2LT in, they all show front and rear staggered sizes. Even though the 2LT RS wasn't sold with front and rear staggered size wheels.
Most of the wheels that I like have a +35 offset. My camaro is Nightfall Grey and I want to go with black or dark wheels.
I really like these 4play wheels but they're a +35 offset.
Glenn
Old 10-18-2022, 09:01 PM   #4
truckrglenn
Originally Posted by RamAir02 View Post
Buy:
- 20" wheels
- 8.5" width
- ET25 offset
That I know, but are there other sizes? I'm asking because there seems to be very few choices at that OEM size.
Like can I run a 20"x8.5" +35 offset with those tires and no rubbing? Or rubbing only when the wheels are turn completely left or right?
Like can I run a 20"x9" +35 offset with those tires?
Glenn
Old 10-18-2022, 09:54 PM   #5
enzia35
Drives: '16 Garnet Red 1SS
APEX wheels and get the DWS06+. The BFG are directional and can't be rotated criss cross apple sauce.
'16 Camaro 1SS
'18 Miata GT
Old 10-18-2022, 10:24 PM   #6
RamAir02
RamAir02's Avatar
https://www.mrrwheels.com/collections/wheels Get in touch with them. They're a forum sponsor and the wheels are reasonably priced. Most (if not all) are replicas.
I bought my wheels from PK Auto Design. Also a forum sponsor, very knowledgeable and they carry a wide selection, but typically a higher price tier and you mentioned being on a fixed income.
YouTube
Old 10-19-2022, 02:28 AM   #7
truckrglenn
whew, those are out of my price range at this time. I wasn't planning this but I had a side wall give out and split open. It's still hold air, but I'm not driving it. The tires are the originals with 30,000 miles on them but over 5 years old.
I might just have to go with new tires for the time being. Temps are dipping early here in Tennessee and it a bit chilly riding my Fatboy after the son goes down.
My budget after taxes is definitely under $2500. I figured that it'd be cheaper in the long run to buy both now, then have to have the tires remounted in the future.
From all of my reading, I gather that if I go with 20"x8.5" wheel, the offset can be between +20 to +35 and I'll be ok without any rubbing. Please correct me if I'm wrong.
Glenn
Old 10-19-2022, 07:13 AM   #8
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I would not go more than +30 offset. The wheels will be in closer and stance will not look good. Tire rack has some nice 20" with+20 offset. You could get a19" wheel and use a 245-45-19 tire.
Gen6cyl is offline   Reply With Quote
Old 10-19-2022, 10:24 AM   #9
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Maybe try Craigslist for a set of someone's factory take-off wheels in your local area? That's one way to freshen up your wheels and maybe change up your look, on a budget.
Old 10-19-2022, 12:10 PM   #10
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
+1 ... I would also scan our member's classified here. Many times people want to sell their very fresh originals when they put aftermarket wheels on, often with almost new tires installed and tpms ready to go.
fj5gtx is offline   Reply With Quote
Old 10-19-2022, 12:43 PM   #11
truckrglenn
I'll check them out.
Glenn
Old 10-19-2022, 09:54 PM   #12
truckrglenn
One last question, I hope. Will these fit my 2017 Camaro 2LT RS Convertible: 20" Black 5443 Wheels SET of (4) Fits Camaro - SS Style Rim 20x9 (non-staggered). Just noticed that the offset is 35. Dam, cause I can get a new set of 4 for $772.00.
Glenn
Old 10-19-2022, 11:35 PM   #13
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
I sold my factory black satin finish upgraded wheels with tires (<3k miles) for like $800 on here a couple years ago. Watch the classifieds, that’s what I would do in your situation.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 10-20-2022, 07:19 AM   #14
GXP08jrf
Drives: 2016 1LT 'Vert
Refurbish option?
Do some searching and see if you can find a reputable wheel repair business in your region. As long as your wheels are only curb rash and moderate scrapes, wheel refurbishing may be a cheaper alternative. I imagine if you wanted them repaired and painted black, this could be done for cheaper than a new set, and you wouldn’t need to worry about fit at all.
For reference I had OEM machine face wheels (not the Camaro’s) redone for $125 each last summer.
GXP08jrf is offline   Reply With Quote
