TireRack
Old 10-16-2022, 03:25 PM   #1
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
Titanium vs steel retainers
When do you really need titanium retainers and how much do they really benefit you with a smaller vvt cam?
Just wondering experiences. I was told I don't need them for my cam as it has a 216-228 duration and max 620s lift but I wanted to see what the pros and cons of them are from those who have done them before. Price difference is about $70 dollars between them.
Thanks
ss camaro-monte is offline   Reply With Quote
Old 10-19-2022, 08:30 AM   #2
LS1Formulation
Drives: '13 Camaro SS '98 Firebird Formula
The difference comes in when you're running much higher RPM, as the titanium material lowers the dynamic weight of the valvetrain. I'm guessing you have an L99? So your intake valves are heavier, and you might benefit from titanium at a lower RPM. What spring package you run makes a difference as well, as a dual spring setup needs a physically larger retainer, where the switch to titanium makes more sense from a weight savings standpoint. I'm running BTR .660 duals, and I opted for a titanium retainer for that reason. However, if you have a beehive or conical spring package, the switch from steel to titanium may not save enough weight to be worth it, unless you're shooting for max RPM. Hope this helps.
LS1Formulation is offline   Reply With Quote
Old 10-19-2022, 10:17 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ concur on this. Plus titanium is harder and stronger than steel. And will last longer.
1JEWLDSSRS is offline   Reply With Quote
Old 10-20-2022, 10:15 AM   #4
Boother
Drives: 14 ZL1
Actually it is the opposite. Steel retainers have a longer life than Titanium and are better for street use.
Boother is offline   Reply With Quote
Old 10-20-2022, 11:46 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Titanium is also more brittle than steel IIRCC
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 10-20-2022, 03:49 PM   #6
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
This was fun. Theres what happened when a rocker got snapped.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 10-20-2022, 07:15 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Got me curious, so I had to check it out. Interesting reading.
https://www.bing.com/search?q=which+...415be5908fc2aa
Old 10-20-2022, 07:19 PM   #8
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
What the heck,kinda makes me wish I went with steel instead of Titanium now !
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is offline   Reply With Quote
Old 10-20-2022, 08:25 PM   #9
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Stage 4 and custom cams for high rpm I would never consider steel retainers.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 10-21-2022, 08:52 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Chris, I forgot to ask yesterday, what the heck caused that failure?? Wow..
Old 10-22-2022, 12:26 PM   #11
Chris49066SS
Drives: 2010 SS L99
Not sure bud. It just started running weak one day back in 2019, about 6 months after I got my cam and stuff done, then when I took it in a couple months later for the intake, the thing dyno'd at 370 hp (down about 110 rwhp) and they replaced the broken rocker and showed me what had happened to that piece. It held on but was all chewed up. Then last time I took it in when they did the valve springs they said one of the valve guides had came out. I feel I've avoided a catastrophic engine failure at least twice!!
I've been wanting to go to a T&D shaft mount rocker for a while, but ya know. $$$$
Old 10-24-2022, 09:46 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I recently saw tool steel retainers from a few different manufacturers, ie Lunati, Comp.
Are these different from the 'steel' retainers all manufacturers offer?
InFiD3ViL is offline   Reply With Quote
Old 10-25-2022, 09:56 AM   #13
Bo White
Bo White's Avatar
I put 45k miles on my TSP springs with ti retainers and only replaced the springs. I reused everything else.
Totalled:
Old 10-25-2022, 03:49 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I worked in a tooling shop back some time ago as a tool and die apprentice and we used tool steel, which is a bit harder than regular steel to make our 10 ton punch press dies for cutting and shaping " other steels. Here is a good read about the 2 different steels.
https://sage-answers.com/what-is-the..._regular_steel
