Old 10-15-2022, 05:28 PM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
What spark plug gap are you running?
I am running LTR7IX-11 NGK’s gapped at .043. I have been advised to run this gap. The theory goes that the wider the gap the better the combustion. What do you guys think?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 10-15-2022, 05:52 PM   #2
Z OH 6
Drives: 2021 Red Hot ZL1
In theory you would always want to run the widest gap that's still effective without losing your spark, but as you increase boost, you will have to shorten the gap. Hate to say it, but it's a bit of trial error unless you have someone that has been there done that and can tell you which gap to use. Most shops will know what works and what doesn't for the given mods.
Old 10-15-2022, 07:00 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’m really surprised JRE recommended a gap that wide on a modded and boosted engine. What kind of boost levels are you seeing?
Old 10-15-2022, 09:35 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If it's not missing up top then don't worry about it. You will know when the gap is too wide.
Old 10-15-2022, 09:55 PM   #5
SATINSTEEL1LE
Drives: 21 ZL1
.032 for my 6510s on my maggie 2650 ZL1. Runs like a raped ape and idles smooth as glass.
SATINSTEEL1LE is offline   Reply With Quote
Old 10-15-2022, 10:07 PM   #6
MartinLe
MartinLe's Avatar
I am seeing high 14 - low 15psi. I am not seeing any misfire.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 10-15-2022, 10:10 PM   #7
MartinLe
MartinLe's Avatar
Can’t say she idles smooth with the cam, but she is right next to your ape clawing for traction 🤣
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 10-16-2022, 03:23 AM   #8
ZL14ever
Drives: 2018 Camaro ZL1 A10
0.031" (stock gap for denso ITV27). Maggie 2650 at 20 psi
ZL14ever is offline   Reply With Quote
Old 10-16-2022, 01:22 PM   #9
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
.40 gap for my 6510s with cam and FBO.
ChadSZL1 is offline   Reply With Quote
