Old 10-14-2022, 08:57 AM   #1
wrankin
Camaros Of Northwest Ohio
Drives: 2016 Black 2SS
2023 SS 1LE allocation, finally
I ordered a 2022 1LE back in early April, and changed to a 2023 at the end of April, before I found out 1LEs were moving to FS. A couple of weeks ago, I finally got a 2023 SS 1LE allocation. I currently run a 2016 SS in FS, so I'm hoping to be a bit more competitive to the local fast guys. I will be ordering the APEX ARC-8 19" setup on black Friday, along with Falkens in a 305 / 315 staggered setup. So I have a couple of questions
  • Will the 315s require the wiring harness relocation?
  • Front sway bar change - Will this make much of a difference, and if so, a recommendation
  • Any other recommended legal minor mods for FS?
I was also able to add the copper free brake option recommended by @apexit53
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 10-14-2022, 11:51 AM   #2
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
The sway bar will make a small amount of difference if any. Drive with the stocker for a while. The 1LE cars and ZL1's have the harness moved from the factory. After the sway bar and wheels/tires mods will put you in a modified class or CAMC.
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 10-14-2022, 12:40 PM   #3
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
My 2020 SS 1LE did not have the harness relocated from the factory. I just relocated it myself recently after 315s appear to have started wearing a hole in the liner. It's easy to check, and if yours turns out to still be in the old location, just relocate it.
Most (maybe all?) top FS drivers nationally run either the BMR or Hotchkiss adjustable front bars. I run a BMR, and the advantage to it is that on its softest setting it's basically the same stiffness as stock. The disadvantage is that the center bushings have not held up well for a lot of folks. I personally inspect mine and have decided to replace just those bushings (they are cheap) once a year even if all looks well. There's a big thread on that somewhere here, and one person came up with a fix. The Hotchkiss bar has the same 1/25" outer diameter but a thicker wall thickness (both bars are hollow). So its softest setting is significantly stiffer than stock. I love the turn-in you get with stock front roll stiffness, but it seems to put power down better with at least one step stiffer front bar.
The other obvious "mod" is to get it aligned. Dial in all the camber you can in front and zero toe. In back, toe will be the limiter for camber: dial in all the camber you can while keeping 0-1/16" toe.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 10-14-2022, 02:01 PM   #4
wrankin
Good approach - drive what you have, at first.
It's easy enough to check the location of the harness, and will do so when I get the car.
Thanks
Bill
Old 10-14-2022, 02:15 PM   #5
wrankin
I have MMR 1LE replica wheels that I run sometimes, and started getting wear from 305 20s after a track alignment. I think the MRRs have a little less offset than the stock 1LE wheels. Just as you said, easy enough to relocate.
I installed the 1LE front bar on my plain SS and I have a track alignment, however they were not able to get to the full specs. A Camaro friend mentioned taking the adjustment bolts out completely and cleaning and brushing behind them and then you can get more than enough camber.
I am familiar with the BMR bars, I just never pulled the trigger. It's good that stock stiffness is the starting point.
Thanks
Bill
Old 10-14-2022, 02:49 PM   #6
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
I have had no issue with the harness but i also only race on them. i dont drive on the street with them. if you plan on that then i would move it.
as mentioned above. do a few events stock, with falkens, get a feel for it then change it
#53 F Street
2025 FS National Champion
2025 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 10-14-2022, 03:19 PM   #7
wrankin
Sounds good.
Bill
Old 10-17-2022, 05:56 PM   #8
cdrptrks
cdrptrks's Avatar
Here's a detailed description of how to release the hidden splines on the front strut to knuckle bolts to get max front camber with an illustration at the bottom: https://www.camaro6.com/forums/showt...7#post10957287
Old 10-18-2022, 05:12 AM   #9
wrankin
Thanks for your detailed response. When I get my 1LE, I will take this information with me.
Bill
