![]() Drives: Camaro Fifty RS & Ford Mustang 2.3 Join Date: Mar 2022
Hello folks,
I own a Fifty edition 8 speed automatic, and currently have two questions: 1. Would it make an issue to remove the cover of the engine? I would love to have the engine - collectors visible. 2. Being automatic I can't rev it in neutral over 3500-4000. Is there any reason why its like that? I've been told I can reprogram it to be able to rev it. I changed the exhaust system and i love how it sounds, would love to make a similar noise stopped when people ask to rev it hahahahaha. Im scared if i remove that limit i might break it or something similar. Thank you. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
1. I don't believe it matters, its just a plastic engine cover.
2. It is rev limited to 4k RPM Apologies if this information isn't accurate. Someone will chime in to correct me if I am mistaken. I know I put my car in neutral when I want to do a high rpm rev. But as you said, my car is tuned so maybe they removed it on my car?
#3 | |
![]() ![]() ![]() Drives: 2020 LT1 M6 Join Date: Jan 2016
. Thank goodness GM has faith in us 6 speed manual drivers, no such restrictions for us.
#4 | |
*cough* Usually people do that at the dragstrip though.
#6 | |
#7 | |
#8 |
![]() Drives: 2018 Camaro SS vert Join Date: Oct 2020
Cover is easy, just remove coil pack covers and it's a couple bolts then off
Once you see the ugly manifold you may want to put it back on though
#9 |
![]() ![]() Drives: 2021 300 Join Date: Jan 2015
Good way to damage a motor free reving over 4000rpm. There's a reason they limit it.
#10 |
Does your A8 have the current spec fluid?
#11 |
It's in the rev limit per gear tables. Park and Neutral are limited to 4k rpm.
#12 |
#13 | |
Someone forgot to tell all the track stars on these forums running at 4000-6600 rpms on track with their cars they shouldn't do this. Or anyone on the dragstrip. My understanding is these cars are designed and built with performance tolerances. As such, below redline good, above redline bad. Wear and tear is no different otherwise. Shy of reving 4000+ for 30 minutes straight and only driving 5 miles. Sure the car has low mileage but the engine has more wear and tear than the mileage of the car.
#14 | |
![]() Drives: 2016 Camaro 2SS Join Date: Mar 2018
Mr Russ
Tim "the tool man" Taylor is my hero My Garage: '16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red -- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned '20 Honda Oddysey Elite 25th Anniversary Edition --wifes car, she said "No more SUV's" after the 2 CX-9's totaled |
