![]() Drives: Camaro 2SS 2017 Join Date: Jan 2022
Cooling, upping RPMs and guess my HP
Hey guys, finally dropping my car off for install of the parts in my signature. P1SC stage 2 (yes it’s tiny)is already installed with kooks 2 inch headers and lt4 in tank and made 553hp/ 490tq. It runs good but I want more. Probably going with 3.7 pulley and E60 hopefully. Now to my question. What do people think of meth for just cooling? Not going to use it for fueling. And I’m considering upping rpm’s to 7000. I bought Caddy Racing lifters. Is 7000 a little high or am i safe. And since I’ve changed my setup so much it would fun to hear your guesses on horsepower based on this setup.
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT 2Forge 19" wheels daily, Forgestar D5 17" for track |
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
If you're running E60, no need for meth. I'm on 93 and made 722 without it. Also spinning mine to 7,000 without any issues. You should be able to max the P1SC out, probably time to go up to a D1X. Your cam doesn't have much duration on the intake side though.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
#3 | |
P1sc turned up will need meth to cool the air temp or you will have to adjust the air temp vs spark retard table to not pull timing until about 170 degrees on E. But make sure to never run the car hard on pump gas if you do that.
#5 | |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
So adjusting the air temp and spark retard tables to not pull timing until 170 degrees will create too LEAN of an environment with 93 ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
Moderator
King is saying that if you push the car hard on pump gas, the car will very likely detonate and smoke the stock bottom end since you’ve instructed the car not to pull timing. E85 gives you a cooling effect and provides a massive safety margin against detonation, so you can not pull timing and still be fine.
#7 | |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
So tuning the iat vs timing for best performance on E isnt going to play nice on 93.
#8 | |
#9 |
^What these guys said.
#10 |
#11 |
This is why i love this forum. I learn something every day. Thanks for the explanation guys. Might skip meth and just go at least e60 and then upgrade to a D1X if i can handle my current build. Tires will be a must. I think my 275s PS4S is going to be a little bit too small lol
#12 | |
Moderator
