10-09-2022, 08:48 PM | #1 |
Drives: 2023 ZL1 Convertible, 1998 Z28 Join Date: Jan 2013
Distorted Glass
I just picked up my 2023 convertible, and I have noticed there is a spot in the glass that distorts the view in the mirror. This distortion is not present in the mirror with the top down.
When I had my 2016, the dealer replaced the top due to glue/glass separation. The replacement top had this same issue and had to be replaced a second time. Is this issue that common, or do I just have really crappy luck.
2023 Rapid Blue ZL1 Convertible
10-10-2022, 04:26 AM | #2 |
Drives: Supra, GTR R-34, RX-7 Join Date: Aug 2022
using a better glue to fix the glass and getting the removable top checked up is it properly aligned or not.
10-10-2022, 05:31 AM | #3 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
I've already gotten used to the rearview camera in the mirror. If my rear glass has a flaw I wouldn't know. It's already been tinted.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
10-10-2022, 06:22 AM | #4 | |
I have been trying. Still slightly distracting as it is all movement without a stationary frame of reference.
10-18-2022, 04:14 PM | #5 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
Possible solution - drive faster - then it doesn’t matter what’s behind you!
(My sympathies to you, seems like there’s a lot of rear glass issues. My 2017 vert is OK…) |
10-20-2022, 09:40 PM | #6 |
My 16 had the glass separation issue. Top was replaced under warranty. New top had the distortion issue. Top had to be replaced again. No issues with the second. I just thought that was some fluke. Never would have expected it again on a new 23.
10-25-2022, 10:47 AM | #7 |
Drives: '23 LT1 conv, '07 911 Turbo Join Date: Jun 2018
Something else to think about. Even with the top up, the window is under tremendous turbulence when the windows are down. This will over time, cause issues with delamination from the movement caused by wind. If you have a wind deflector, always use it even with the top up and the windows down. It will still cut down on that wind inside the cabin. Plus when you also roll down the windows, be sure to roll the quarter windows down as well as that seems to help. Just some things I've noticed in the month since mine was delivered.
