![]() Drives: 1970 Boss 302 Join Date: May 2009
update to order cancellation -new option
I previously posted that I ordered a 2023 Sharkskin LT1 with dual mode and automatic in May. As of late September, no movement at all so I cancelled.
I came across a 2023 1SS, gray with recaros, automatic, sunroof, dual mode exhaust, and wrapped wheel and shifter. Of course, it's more but can get 500.00 off sticker. I was wondering if a 1SS might be a better choice? I've got the car held till Monday. Thanks. Last edited by larietrope; 10-08-2022 at 10:31 PM. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
Thank you Al Oppenheiser!
Test fit the sunroof car if you're going to wear a helmet.
![]() Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
I also was looking at LT1 and 1SS vehicles. Other than looks and spoilers the biggest difference is the wider tires. 275 summer tires in the rear are going to really improve handling and grip over the 245 all season tires on the LT1. It also gives you the bigger screen even if you don’t get a Bose sound system.
But if you want the Bose system then you can only get that option on a 1LT. 1SS does not offer that. Good luck. Either car is a fine choice. Hope it all works out. |
2020 Shadow Gray 2SS
1SS all day, every day... Many more advantages over the LT1 than just wider rear tires... If you can afford the 1SS, much better than the LT1...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
![]() Drives: 2022 LT1/RS Join Date: Sep 2016
I like the gauges on the SS better, although all that info is there on the LT1 you just need to scroll through.
I find the BOSE to be a must have, it really sounds great. 4 pipe exhaust FOR SURE the one thing I would not go without. If you are not track driving then at least you can rotate the tires on the LT1. I wanted to order the Recaros and skip the sunroof, the car I ended up finding (nearly new) had those flipped LOL - I am liking using the sunroof however it does mess up headroom. Sort of on that topic, why do these seats not recline further????????????
2022 Black Camaro LT1/RS, Dual Mode Exhaust, Power Sunroof, BOSE, Carbon Flash Alloys, RS pkg, Tint Other Chevys: Tahoe Z71, Volt, Cheyenne Pickup, Prizm LSi Plus several Mazdas and Toyotas, one Acura |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Get the 1SS with the Recaro seat option.
#8 | |
![]() Drives: 22 LT1 Join Date: Oct 2022
