Old 10-07-2022, 09:24 PM   #1
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
DMS ZL1 2 Gallon Supercharger Fender Tank Install
Installed the DMS 2 gallon fender tank tonight. Mounting the tank was fairly easy. Routing the hoses was not. I have already some minor mods to my hoses from the Cordes tank I'm replacing so I kinda just did what worked.
They didn't have instructions for 6th gen Camaro but have some for CTS-V that helped with making sure I mounted the tank as they expected. The one 90° bend could have been a 45° at the bottom, my installation sat back further that was shown in the CTS-V (where that 90° bend works better). Bottom hose goes into the top (inlet) of the pump and top hose goes to the top right supercharger fitting (outlet). My routing of the lower hose made installing the fender liner a little snug but it went into place.
Quality of the tank was nice, comes with a bleeder hose for the top. Filled the system up tonight and will do some topping off in the morning as bubbles rise. I wound up installing the tank that came with my 2300 that was never installed originally as my fill point, see how it all pans out.
Note you can also see the notches I put in my shock for the 19x11 wheels I run up front, I hit them with some paint afterwards and its holding up well.
Old 01-23-2023, 11:41 AM   #2
Marozl1LE
Drives: Camaro gen 6 zl1 1le
Thanks for the Post Do you feel any difference to the stock system ??
I order it already heat exchanger for my zl1 but maybe I will order the fender tank too it will be working good
Marozl1LE is offline   Reply With Quote
Old 02-14-2023, 01:11 AM   #3
Marozl1LE
up
Old 02-14-2023, 08:01 AM   #4
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
nice that's a great way to add the volume and not try to fit under the crowded hood!
Old 02-14-2023, 08:14 AM   #5
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Yes,
I want to test it out in the heat of the summer but in October my IATs were cooler and recovering faster with this tank.
Old 02-14-2023, 03:20 PM   #6
Marozl1LE
Originally Posted by LiqTenExp View Post
Yes,
I would try this after I change the heat exchanger but Mr weapon x don't want to ship i think after 50000 years it will be arrived it's so sad it make me cry
Old 05-23-2023, 05:37 PM   #7
Marozl1LE
Up
Old 05-23-2023, 05:40 PM   #8
WillyZ83
WillyZ83's Avatar
Drives: 18 zl1 garnet red
I had this system in my previous car and I noticed a difference for sure. Was a good choice for coolin
IG - @zl1_will
2022 zl1 740hp / 730tq stolen
2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms
WillyZ83 is offline   Reply With Quote
Old 05-23-2023, 06:55 PM   #9
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Can you post a picture of the bleeder hose on the top. I have the exact same tank. Also how did you route the hoses for the reservoir you have in the engine bay? Wanting to do something similar but with the adm reservoir
Nimair.ZL1 is offline   Reply With Quote
Old 06-25-2023, 03:00 PM   #10
ZL1...SON
Drives: 2021 Camaro ZL1
What are you thoughts on the DMS fender tank vs the Cordes tank you have on your current car?
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR
ZL1...SON is offline   Reply With Quote
Old 06-28-2023, 09:39 AM   #11
ZL1...SON
Did you have any issues with fitment of the tank, or did the tank cause any alignment issues with the fender and door? I spoke with WillyZ83 about his tank and he had some alignment issues after installation. It looks like there is a little bit of a gap between the tank and fender in your pictures, but that could just be due to the picture and angle. Or maybe they revised the tank a little after the tank that WillyZ38 had. Just trying to decide between this tank and the Moroso tank but don't want to create any aesthetic issues along the way.
Old 06-29-2023, 09:20 AM   #12
laynlo15
Drives: 2022 Lt1 A10
Now you need to get the TooHighPsi Port Injection, keep that 2300 and you'll be stellar. I love mine and my intake temps are already low, I have the bigger intercooler up front so mine stay right around 100 even on a hot day. When I'm drag racing on a low to mid 80s day my Iat's are generally about 120 in the stagging lanes and about the same before I start my burn out and 90 to 100 at the end of the run. I'd like to see what your Iat's are, I'm sure they are pretty low.
Old 06-29-2023, 09:30 AM   #13
laynlo15
Looks like a straightforward install and might look into it in the future, any extra coolant moving thru the system is a plus. Nice job.
Where did you mount your coils?
Old 01-11-2024, 09:43 PM   #14
Marozl1LE
What is now with your long time experience?? I want this too but it's freaking expensive if anyone had one pls contact me
