10-06-2022, 10:50 AM | #1 |
Rear End Decisions/Input
Alright guys I need some input, and I'm sure this has been asked a few times but here we go. I have been trying to find a Strange S60 with little to no luck, I contacted them yesterday and they are so far out they cant even get me a projected time frame.
Reasoning: End of last summer I went around a corner hard and the ass end slid and I heard a pop. Next thing I know I'm getting a clicking noise in 1st gear low rpm which sounds like its coming from an axle but I have DSS 1400hp axles and they seem ok as far as tightness within the joints, I took the stubs out of the hubs to check teeth and all good. I dropped my oil in the stock diff and zero signs of shavings. I will be sending them into DSS this winter to check. I still have stock 2-piece DS and haven't checked the center support bearing, but was planning on going 1-piece here soon anyways. I also did notice what seems to be a bit more than normal backlash at the differential yolk, so it really could be anything at this point. I don't really see myself going more than 900-1000whp in the near future. So that leaves me with should I order and wait and hopefully someday get the S60 or just throw a trutrac in my stock diff and a potential rebuild? Our season is pretty much over up north and I have time, I just don't want to be in a bind come next spring. All thoughts much appreciated!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
10-06-2022, 11:42 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Upgrading to a Torsen style carrier in your current diff would allow you to keep your current axles without having to change anything. Biggest risk would be going from a dig on a sticky tire. I have a Z28 diff in my vert, but not near your power level. I use a ZL1 diff in the turbo car with Gforce Outlaw axles. I have Outlaws because I broke a ZL1 axle coming off the line with a 10" slick on an 18" wheel. I'm pushing 100 less hp than you are but a touch more torque and I run an LNC 2000 for a two-step retarding 14 degrees. My concern would be, given you have the 1400hp axles, your diff would become the weak link.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-06-2022, 12:58 PM | #3 |
GPI Sales Consultant
Having gone through this for several years - I feel well equipped to give you my two cents.
It all comes down to usage. There are plenty of high horsepower cars out there that run around on street tires and maybe do some highway pulls, but never really do super aggressive launches with big traction. Those cars can survive a long time on the OEM SS parts. But, once you start asking the rear end to make aggressive drag strip launches... it's an when, and not an if it's going to fail. If you fall into this second category of sticky tires (I see your sig pic!) and hard launches, the OEM 218mm rear end is always going to leave you disappointed, no matter what you do it. I went through several iterations of mine with different gears, the LPW support cover, TruTrac - and it still never had the ability to truly cope long term with the violence even a naturally aspirated stick shift car will dish out when launched aggressively. I've done all kinds of stuff to remove abuse from my launch, and I believe I've done that well, but when you start really asking all you can from it, it will fail you. So, if that's you, I would save your money and not invest into a rear-end that's not ever going to give you the reliability you want. Take that money saved, and put it into something that will take the power you want to feed it with a smile on it's face. Keep your stock rear end in good condition, and when you sell it along with the axles, it will finance a decent chuck of the S60 or 9" that you end up with. Yes, those (especially the 9") are super pricey options, but for the long term on a car you intend to keep an enjoy without an expiration date, it's worth doing. Like I said, I've bought, built, or rebuilt - no joke - five iterations of the 218mm rear end. I broke Richmond gears, and I hurt but didn't destroy Motive gears and Yukon gears. I broke a OEM posi unit. I hurt but didn't kill an OEM axle. For what I've spent on 218mm SS rear ends, plus the value of selling the OEM diff, axles, and drive shaft, it would have funded 75% of what a NEW 9" setup costs, and would have completely funded what I have into my current used setup, even with a gear change. I drag race the car regularly, and I wish I had someone talk me into just doing it "right" the first time. Not to mention, my 9" is quieter, and smoother than even a well built OEM diff, and I've got a gear ratio you could never get in the OEM setup.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
10-06-2022, 02:25 PM | #4 | ||
The S60 is compatible with my DSS axles as well (reason for wanting the 9-3/4"), you just take the diff side spline off. So that's the other reason to go to the S60. I agree on the weak link as well, its taken about 3 years of abuse. Some hard launches on on my 15" setup for a solid 2 years. I only go to the strip maybe 3-4 times a year. Appreciate the input! Quote:
2014 1LE - Sold
10-07-2022, 06:52 AM | #5 |
Hey - we're to help (you spend your money)!
I think you'll be happy with the S60 or the 9". S60 was my top pick, for more efficiency, but couldn't get the rock crawler gears I wanted for this all motor stuff, and then my used 9" setup just came together for me. My only regret is not doing it sooner.
10-07-2022, 09:11 AM | #6 |
Drives: 2010 SS L99 Join Date: Sep 2018
Andrew have you got timeslips yet, whats that thing running these days? Awesome setup! (not trying to threadjack, just curious!)
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
10-07-2022, 09:31 AM | #7 | |
Awesome man! Yeah tbh I love my 3.91's for a turbo car but I am having to shift into 4th at the line so I hope with the 3.73's I can stay in 3rd a little longer.
2014 1LE - Sold
10-07-2022, 09:54 AM | #8 | |
Now we're really late in the season and scrambling for places to go that fit in with a busy schedule. Weather looks great tomorrow - all my child care is out of town! Next two weekends are booked both days. I have a few hail Mary's left for this fall coming up the next couple Friday's - hoping to try to find that elusive 10.99 slip. It should do it. I ran a very conservative launch on the street last week for giggles (2.15 60') and it went a 12.01@123.67 on the draggy, so I think that'll dip into the 10's on a 1.5x 60', and probably run 127 or better out the back. I've got the race weight under 4,000lbs now, more power, and PLENTY of gear and traction, so just gotta put it all together.
10-07-2022, 09:56 AM | #9 | |
4.10s on a 28" tire would be 6900rpm @ 140mph, 7400rpm @150mph. Plenty to make it out the back with big MPH, helps the car leave with less RPM and slip, and gives you better average power and shift recovery over the run. 3.73 is still only going to go 120mph @7000rpm, which ain't gonna get you anywhere near the traps, and its gonna lay down on that 3-4 shift pretty good. I would hope 800whp would trap in the high 130s to low 140s depending on weight. I'm not sure what RPM you turn, but even 8000rpm is only gonna see 137mph in 3rd.
10-07-2022, 10:04 AM | #10 | |
To each their own I suppose, ha! My 60' @1.8 for a stick car is pretty decent for now. I called strange again on ETA's and they couldn't tell me anything once again, plus paying for the entire unit up front and waiting on a maybe in the next several months isn't in the cards for me at this time. Hopefully I can find one somewhere or just sell my DSS axles and get a diff/axle/ds setup from gforce.
2014 1LE - Sold
10-07-2022, 12:44 PM | #11 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
What I've learned: > My heavy Gen 5 needs more RPM to launch > The 4.11 rear 9" gears have helped a lot over the 3.25. The 3.73 were good though. > I have the ZL1/1LE transmission gears and I cross the finish line at the top of 4th gear, shift light a'blaring set at 6.7k (actual RPMs are 6,750) - with boost getting me around 905whp per trap speed calculations. > I will need to spin the motor to 7,300rpm to cross at 150mph (my target) with my 4.11 in 4th gear. > Setting up a car that I want to do: drag, autocross, daily and Mile is doable, but it's not going to do great at any one of them, but good enough.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
10-07-2022, 01:06 PM | #12 | |
My deal is pretty close to perfect for what I need it to be out the back, and it gives me a 14:1 starting line ratio, which sounds pretty aggressive, but works really well. I wanna make 2 tons go 1.5xx in the 60'. When I look at Draggy data of leaving at like 2500rpm on the street with moderate at best traction, I see peak G's at the top of first gear - which tells me that when this thing hooks from a dig it's gonna pull good G's all the way and really leave like it was rear-ended. At least I hope - it's all theory till it happens. I don't know of anyone that's put this much gear in one of these. Having a car that 60's hard and can run standing mile is gonna be a struggle, that's just a massive ratio spread that's not really available in any practical way. It would be interesting to talk with guys that do that regularly and successfully to see what they do. Mostly what I see at 1/2 mile and mile stuff is pretty mild/moderate launches and they just feed the power in after they get it rolling.
10-07-2022, 01:20 PM | #13 | |
Great info here, we are a lot the same in leaving the line at the same rpm my 2step is also set at 3psi and some timing retard. I spin my motor to 7200 is the only difference. Gearing will sure help, however, now both of you may make me change to a 4.10.
2014 1LE - Sold
10-07-2022, 03:23 PM | #14 | |
