![]() Drives: Camaro ZL1 , Corvette ZO6 Join Date: Mar 2019
What problems would someone expect to see if E-90 was added to a stock ZL1 that has not been set up for it ? Don't worry , I have not done that but it is becoming available close by and I am considering some horsepower upgrades . I appreciate any constructive comments . :wave
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I'd expect it to run lean and melt pistons.
#3 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Bad things.... very bad things...
Mix it down, otherwise you'll be looking at a shiny new LT4 crate engine and your $20k lighter wallet soon.
Drives: 21 ZL1 Join Date: Feb 2022
Yeah your car is setup for e10. You do the math.
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
The stock tune is good up to ~95 octane. More than that, you're going to gain nothing in power.
Adding too much will cause damage, as stated. |
#7 | |
Black lightning
[ 2021 Camaro ZLE 10 speed
#8 |
![]() Drives: Camaro ZL1 Join Date: May 2020
Your going to hear, BOMB!!!!
#9 |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Ethanol has a much lower energy content per gallon than gasoline, so you need much more fuel flow with E. Without a tune your computer will think it’s burning gasoline, and won’t send nearly enough fuel, and that will ruin your day.
Octane and energy density of the fuel are two different things. You could mix 100 octane unleaded race gas with 91 or 93 octane gas and achieve higher overall octane gasoline.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Someone is going to let the smoke out of that LT4.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
it will go into limp mode when the high side fuel pressure drops below threshold...there is a bit of self preservation built into the stock tune. Definitely don't run E without a tune to enable the ethanol % tables and the appropriate flex fuel sensor kit.
#13 |
Assuming the ECM is going to be quicker to put the car into a "limp mode" vs detonation happening is a fools errand.
#14 |
The ECM is very quick and will enter RPM before bad things happen to the engine. It's still not a smart move either way.
