10-04-2022, 11:29 AM | #1 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Battery Maintainer for winter.
Are you removing your batteries to put on a maintainer for winter? If not, are you leaving the trunk open for ventilation?
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
10-04-2022, 11:37 AM | #2 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
10-04-2022, 12:00 PM | #3 |
Yes, but the battery being charged is still in the trunk. The maintainer instructions are pretty clear about only charging in a ventilated space.
10-04-2022, 12:11 PM | #4 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
I looked in the trunk and the positive is buried behind the back trim. I saw the engine compartment location and I'm not crazy about leaving a Battery Tender hooked up there. I'm going to grab a quick connector from Ace Hardware and hook it directly to the battery. Then it will be like the C7 Corvette I had. GM provided the connection with the car.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
10-04-2022, 12:18 PM | #5 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Mine comes out, but I put my car in my storage unit for the winter which does not have electricity. So I take the battery out and put it in my basement on a tender.
10-04-2022, 12:25 PM | #6 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
trunk is ventilated, no need to open it, i have charged my 2018 all year from the front. and its a trickle charger low heat.
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
10-04-2022, 12:27 PM | #7 |
Faster!!!
10-04-2022, 02:34 PM | #8 |
376 cubic inches of fun
10-04-2022, 02:56 PM | #9 |
Thanks guys! I won’t worry about the ventilation, since it is vented.
10-04-2022, 03:41 PM | #10 |
I learned two things today…battery needs to be vented and it already is from the factory. Good post.
10-05-2022, 06:54 AM | #11 |
Hot Camaro
The direct venting to the outside is the only way they were able to locate the battery in the trunk since there's no way to seal off the trunk from the passenger compartment completely (and it's not really a ventilated area itself).
10-05-2022, 08:15 AM | #12 | |
Thank you Al Oppenheiser!
