Old 09-30-2022, 01:30 PM   #1
Huutchh
Drives: Chevrolet Camaro
New fob key.
Good evening from the UK guys.
I own a 2017 50th Anniversary.
I have lost one of my keys I bought a spare from the States, but I'm having issues.
When I insert the newly purchased key into the drivers lock and turn 5 times as per the instructions I'm getting nothing on the DIC.
Anybody have any ideas?
I've attached the key I ordered.
Huutchh is offline   Reply With Quote
Old 09-30-2022, 01:35 PM   #2
JimGnitecki
Drives: Chevrolet Camaro LT1
Chevrolet The image you posted appears to say this fib is for a Malibu, not a Camaro.
Jim G
JimGnitecki is offline   Reply With Quote
Old 09-30-2022, 01:37 PM   #3
Huutchh
Jim G
Underneath it says Camaro, so I assumed it was the correct part.
Old 09-30-2022, 02:15 PM   #4
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Hi Huutchh!,
did you strictly follow the procedure shown on your user's manual? If I remind correctly it's a little bit more complex than that..
See you!,
Eos
Eos is offline   Reply With Quote
Old 09-30-2022, 02:18 PM   #5
Huutchh
Originally Posted by Eos View Post
Hi Huutchh!,
See you!,
Eos
Thanks for the reply Eos!
Yes sir, placed fob I already own in the cup holder. Placed the newly cut key into drivers side lock. Turned 5 times to the left and nothing shows up on the dash.
Unless I'm doing something wrong I believe that is the right procedure.
Old 09-30-2022, 02:41 PM   #6
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Hi Huutchh, you may have to use the other procedure because you only have one recognized fob. The “programming with no recognized key fobs”
Something to note, this procedure is not available in Canadian vehicles.
It unregistered all keys and reprograms all of them. Takes about 30 min.
Sweptwing is offline   Reply With Quote
Old 09-30-2022, 02:47 PM   #7
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
...placed fob I already own in the cup holder. Placed the newly cut key into drivers side lock. Turned 5 times...
You say you bought the new key from the States. First things first. Was the key blank cut to match your existing key? Does the new key unlock the door when you turn it?
17rsvert is offline   Reply With Quote
Old 09-30-2022, 02:57 PM   #8
Huutchh
Yes sir the keys been cut and it fits into the lock and locks and unlocks with no problems.
Old 09-30-2022, 04:18 PM   #9
Sweptwing
Sweptwing's Avatar
Hope you are making some headway! I know that fob works, I purchased the same one and it programmed and works fine. Good luck!
Old 09-30-2022, 04:24 PM   #10
Huutchh
I'll try again in the morning. I just don't get why I get nothing on the dash when I turn the lock. Baffles me
Old 09-30-2022, 04:27 PM   #11
JimGnitecki
Does it matter if the door is open or closed when you do the procedure?
Jim G
Old 09-30-2022, 04:38 PM   #12
Huutchh
Jim G
I've tried both ways mate. Doesn't make a difference.
Old 09-30-2022, 05:34 PM   #13
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Is camaro RHD ?
Maybe they mean LEFT door lock specifically?
ing for grip.
http://www.motorsportsne.com/
Old 09-30-2022, 06:01 PM   #14
Huutchh
Originally Posted by Vtor_ZL1 View Post
Is camaro RHD ?
LHD mate. I might try the passenger door tomorrow. Can't hurt anything.
