Old 09-25-2022, 09:30 PM   #1
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Putting front calipers back on - Loctite or NO?
Hey guys. I need advice from those that track their 1LEs and ZL1s and do their own front rotor replacement:
I know the shop manual says to clean the front brake caliper/bolt threads and use red loctite 272. But the amount of torque I had to apply to break them loose (didn't want to use heat since the upper bolts are so close to the mag-ride sensor wires/connectors) made me worry about risk of shearing off the bolt heads should I reapply new loctite 272. I'm contemplating not reinstalling with loctite and seeing if they stay put with the torque + angle alone.
Has anyone who tracks their car reinstalled the calipers without the red-loctite and if so, did the bolts eventually come loose with track use?
Any point in using blue loctite (caliper temps on track will exceed the blue loctite temp rating?)?
N Camarolina is offline   Reply With Quote
Old 09-25-2022, 09:50 PM   #2
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
I would not risk it. Just a little red goes a long way.
5.M0NSTER is offline   Reply With Quote
Old 09-25-2022, 10:49 PM   #3
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
I would and HAVE used the blue loctite. NEVER any issues with these bolts loossening up.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-26-2022, 06:47 AM   #4
cdb95z28
cdb95z28's Avatar
You won't sheer the bolt. Turn the steering wheel to gain better access to the bolts, get a long breaker bar and go to town. Don't use an impact gun, that is hard on bolts. Yep, the manual specs high temp high strength threadlocker. Permatex 27200 or Loctite 272.
And no heat is needed for the high temp stuff. I've never needed heat for the typical sized bolt on vehicles.
"KEEP THE FAITH"-Fbodfather
Old 09-26-2022, 07:46 AM   #5
BanOne
Drives: 1977 Pontiac Trans Am
Loctite
I had the same question and chose to go with the blue loctite and the torque plus angle. Red loctite seemed to be massive overkill and it was very difficult to get them off the first time.
BanOne is offline   Reply With Quote
Old 09-26-2022, 10:03 AM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Medium is fine for nothing else than to prevent steel bolt from reacting with aluminum caliper.
ing for grip.
http://www.motorsportsne.com/
Old 09-26-2022, 11:33 AM   #7
DaveC113
DaveC113's Avatar
I went with nothing and have been checking them. Not loosening at all after a couple track days and autox races, but next time I remove them I'll probably use blue.
Old 09-26-2022, 12:40 PM   #8
MatthewAMEL
MatthewAMEL's Avatar
You want these if you are going to DIY your rotors...
https://screamingchicken.com/2016-22...caliper-bolts/
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 09-26-2022, 04:15 PM   #9
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
For what purpose?
As for OP's question, I'm also one to err on the side of caution. Maybe won't be an issue going without or using blue as others have posted, but I've been using the GM (ACDelco) red and haven't had an issue. Can get them off with an impact no problem.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 09-26-2022, 10:23 PM   #10
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Not needed. OEM can be reused, just clean and use blue. Torque to spec
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 09-26-2022, 11:01 PM   #11
MatthewAMEL
Can you do that once? Sure. Would I risk doing that multiple times with TTY hardware on something as important as brakes?
For those that like certainty, was just giving an option for hardware you can reuse with no concern.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 09-27-2022, 01:51 AM   #12
cdrptrks
cdrptrks's Avatar
The shop manual tells you to reuse them with red thread locker. They are torque + angle which is different than TTY. The shop manual clearly says to discard and replace other TTY bolts.
I put a dab of red thread locker on a few threads rather than 2/3 of the bolt like the shop manual recommends if I remember correctly. I marked them after torquing and they haven't loosened yet after about 10 months and quite a few track days at different tracks.
Old 09-27-2022, 07:41 AM   #13
cdb95z28
cdb95z28's Avatar
I do the same.
The caliper bolts are not TTY, they are torque to angle.
BRAKE CALIPER FRONT J6H.pdf
BRAKE SYSTEM FASTENER TORQUES.pdf
Old 09-28-2022, 12:14 AM   #14
N Camarolina
Thanks everyone for your thoughts. I decided to go with the red 272, albeit sparingly given the warnings that a little goes a long way.
Just reinstalled the calipers. Torquing to 111 was no prob, but adding the extra angle was really difficult to generate enough torque given the awkward angle. I probably managed about 10 degrees.
