Old 09-25-2022, 08:45 PM   #1
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
416 Conversion questions
Hey,
I'm looking at updating my rotating assembly and stepping up to 416ci displacement. I'm roughly 250-300 whp over stock. I've got almost 30k miles on my current setup.
I'm getting oil on plugs and smell a little oil after coming to a stop. I did new valve seals/springs a couple months ago and that wasn't the source of the oil. It isn't eating oil at any noticeable increased rate compared to typical for it over the years. I don't use a catch can. Some of the smell could be the Metco breather I have. Based on the plugs... is thinking the rings are getting tired @ 15 psi at those miles a good assumption? I did a compression test last year and everything was GTG, going to do one more shortly to just compare it.
I've just started to do research as I don't have much experience here. I see there are a lot of LT4 "packages" from BTR, TSP, etc. I am going to have my local shop do the work and will coordinate this with them but want to educate myself on some of the choices for connecting rods, pistons, rings, cranks, crank bearings.
Any recommendations/suggestions/comments appreciated.
Old 09-25-2022, 09:01 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by LiqTenExp View Post
Hey,
This must be good choice because it seems it's all Pray uses.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 09-26-2022, 09:19 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Do the compression test and if all is good use a catch can... LT4's get quite a bit of blow by through the pcv system.
Old 09-26-2022, 09:38 AM   #4
L78toLT1
L78toLT1's Avatar
Did you check your valve guides when you replaced the springs and seals? If you're running an aftermarket cam & springs, I can't imagine your guides are in very good shape at 30k miles
Baby Blue
Old 09-26-2022, 11:28 AM   #5
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I replaced the valve seals when I did the springs but not guides, I believe technically they were done around 8-9k miles when the majority of the engine work was done. I don't have any smoke on decel that I can see only accel, I should put my gopro on to confirm...
Old 09-26-2022, 03:59 PM   #6
turbo_jimbo
Drives: 2022 ZL1 1LE
I would do a leak down. If that's good, a catch can could fix all of this.
turbo_jimbo is offline   Reply With Quote
Old 09-26-2022, 05:39 PM   #7
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Eh, I know the car, it didn't use to do this. If anything that would be a bandaid. We shall see what the leakdown test says, will likely have time Thurs/Fri this week.
