![]() Drives: 2022 ZL1 1LE Join Date: Sep 2015
OEM Part number??
Hi all,
Does anyone know the OEM part number for the plastic panel under the front end of the engine on a ‘22 ZLE. I ran over a small suitcase in the road which damaged the panel. I’ve looked at GM online parts sites and searched here, but couldn’t find it…likely because I’m not sure exactly what it’s called. The piece starts right behind the radiator and is about 2.5’ x 2.5’, mostly smooth black plastic. Thanks in advance JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
Is it perhaps #22 or #23 on this diagram? https://www.gmpartsdirect.com/v-2022...and-components
arpad,
Thanks but that’s not it. I found all those diagrams also but still haven’t seen the correct part. I’m looking for the flat panel underbody air dam that keeps airflow from entering the engine area. In essence it’s a flat black plastic piece about 2’ x 2’ in size JJ
![]() ![]() ![]() Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
This looks like what you’re after.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
![]() Drives: 2022 ZL1 Join Date: Dec 2021
Can you take a picture?
LeonardS
That’s the one!! And of course it’s back ordered!! Thanks very much for the info. I’ll try some GM parts outlets and try to get it ordered. It sure helps when you know what it’s actually called! Thanks very much again. BTW, how are you liking your new ZLE? JJ
#7 | |
The ZLE is a beauty! I have spent much more time polishing it than driving it, but I enjoy that part of the hobby also.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
I see it available on other sources so check eBay and search via the part number. $85 or so.
