Old 09-24-2022, 08:07 PM   #1
Drnick
Drives: 22’ ZL1
Difference between sport and track mode
What exactly is the difference between sport and track mode
On a ZL1 manual ( non 1LE )in regards to suspension
Steering wheel, throttle input, etc.
Drnick is offline   Reply With Quote
Old 09-24-2022, 08:30 PM   #2
raptor5244
Drives: 2022 CT4-V Blackwing
Track Mode - Steering is heavier, throttle mapping is more linear, magnetic dampers are in firmest setting, NPP exhaust valves are open more.
Track Mode also enables to get into the PTM Modes to further dial in the E-LSD settings.
Name:  Screen Shot 2022-09-24 at 9.26.07 PM.jpg
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 09-25-2022, 07:06 AM   #3
John Simon
Drives: Supra, GTR R-34, RX-7
On the road you notice no difference, but as soon as you start sliding around corners on track, it's instantly noticeable. Sport mode allows a little slip (more than assists on), but if you go too far it absolutely snaps you back into line (even if you were still in control)
John Simon is offline   Reply With Quote
Old 09-25-2022, 09:37 AM   #4
Drnick
Drives: 22’ ZL1
E-LSD? Electronic Limited slip differential , I’m assuming
That’s not in the ZL1 but only in the 1LE version?
Old 09-25-2022, 10:49 AM   #5
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
It’s in both. Unless it’s a convertible.
CW3SF is offline   Reply With Quote
Old 09-25-2022, 05:03 PM   #6
Drnick
Drives: 22’ ZL1
Why not convertible?
Old 09-25-2022, 06:50 PM   #7
raptor5244
The E-differential is not included on the convertible. The assumption is that the vert would not be allowed on most tracks since you would need to install a roll bar/cage, therefore, the extra capabilities of the E-diff would not be utilized. The vert also gets a 2.77 ratio rear axle vs. the 2.85 on the coupe with E-diff.
If you are serious about tracking you wouldn't want the extra weight of a vert anyway. However, if it is a street car the top down experience is fantastic.
2019 Tesla Model 3
Old 10-02-2022, 06:35 PM   #8
Dathomas94
Drives: Camaro 2021 ZL1 6 speed ragtop
F#&king love my ZL1 vert more than my limited hardtop track time
Dathomas94 is offline   Reply With Quote
Old 10-04-2022, 06:50 AM   #9
Callaway_1
Drives: 2018 ZL1 convertible
The ZL1 convertible is a very special beast! I love mine!
Callaway_1 is offline   Reply With Quote
Old 10-04-2022, 07:28 AM   #10
Drnick
Drives: 22’ ZL1
Dittos on that ZL1 in manual and vert in Florida,ya can’t beat!
Old 10-07-2022, 10:24 AM   #11
Timuh60
Timuh60's Avatar
Drives: 23' ZL1, 17' 1SS Vert, 68' SS Vert
One more to send love for my ZL1 vert!! I still wish we were able to track them without modifying with an ungodly roll bar. You don't have to push it to the edge to have fun enjoying the car on a track.
2023 VOM ZL1 Convertible
2017 Camaro 1SS Convertible
1968 Camaro SS Convertible, LS1
Timuh60 is offline   Reply With Quote
Old 10-07-2022, 11:14 AM   #12
vy427
Drives: '21 ZL1 A10 Convertible
I rarely see another ZL1 let alone a convertible. I don’t track so the vert is great. It’s surprisingly well designed, too. Road noise when the top’s up is nearly coupe like, air management when the top’s down is great and the chassis maintains a good level of solidity. There are some noises coming from the top when it’s up (somewhat weather dependent), but not too bad. Agreed, you don’t miss the e-diff during normal driving.
Regarding the OP’s question, the suspension is noticeably stiffer in Track mode. Steering is also noticeably heavier. The muffler valve opens sooner and it crackles more on the overrun. I don’t notice a huge difference in throttle response. The modes are customizable, however. For example, you can select the Tour or Sport suspension setting when in Track mode (or steering and exhaust).
vy427 is offline   Reply With Quote
Old 10-07-2022, 12:32 PM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I don't think the eLSD will fit with the ragtop. I don't think the controller and case will fit with the bracing.
'20 ZL1 Black "Fury"
