Old 09-22-2022, 05:45 PM   #1
Badmojo
aka BeastZL1
Badmojo's Avatar
Video: Stealth Lift Pads from ZL1 Addons
I installed the new version of the ZL1 Addons lift points "Stealth Lift Points" on the "new to me" Camaro ZL1 1LE. These things are essential for any 6th Gen Camaro in my opinion. I like them better than the old version!
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 09-22-2022, 06:15 PM   #2
Allez
Allez's Avatar
Nice video, thanks,
The only concern I have is whether tightening the set screws into the pinch weld could lead to an area where rust could form. Has anyone had that issue (with the old or new version)?
Allez is offline   Reply With Quote
Old 09-22-2022, 06:32 PM   #3
RayKinStL
RayKinStL's Avatar
Drives: 2022 LT1
My set of these (not the stealth, just the regular) came in yesterday. Will be a bit of a bitch to put them on since I don't have anything else to get the car higher off the ground, but we'll get it done.
RayKinStL is offline   Reply With Quote
Old 09-22-2022, 06:39 PM   #4
22SS1LE
Drives: 2022 1SS 1LE 6M
oh it is a PITA. when i put mine on when I brought the car home. I was swearing at it cause its basically installing blind. to make things easier I should have put in place and used my jack to hold that pad while i set the screws. Holding it in place 1 arm and trying to fiddle with the other made it a bitch
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 09-22-2022, 06:52 PM   #5
Uk2019
UK2019
Drives: Camaro 2017 2ss/eu spec convertible
I had the same concerns about rust forming so coated the area the lift pad attaches to with underseal (to help prevent any galvanic corrosion between the aluminium pads and steel body) and made up a thin aluminium plate on the side with the set screws so that the screws themselves wouldn't damage the paint on the pinchweld but pressure would be applied. 2.5 years on they're still in situ and as tight as the day I attached them. I also used blie locktite on the screw threads
Uk2019 is offline   Reply With Quote
Old 09-22-2022, 08:00 PM   #6
ZPirate
ZPirate's Avatar
I installed mine a couple of weeks ago. I used my Race Ramps to get under the car. Fairly easy install when you can see what you are doing.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 09-22-2022, 08:52 PM   #7
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
What's the difference between the stealth and the non-stealth? Is one better than the other?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 09-22-2022, 09:36 PM   #8
ZPirate
ZPirate's Avatar
The stealth version is smaller and lighter and I understand doesn't stick down as far
Old 09-23-2022, 07:43 AM   #9
Allez
Allez's Avatar
Neat solution. Has me thinking . . .
Old 09-23-2022, 01:51 PM   #10
SS_Don
SS_Don's Avatar
Ordered a set.
Old 09-23-2022, 02:54 PM   #11
PostalLDMC
PostalLDMC's Avatar
Drives: 2022 2LT RS Convertible
Just a question?? on the rear why you didn't just lift the car on where the bolts tie the cross steel together. isn't that spot stronger than the rear pinch weld spots.
PostalLDMC is offline   Reply With Quote
Old 09-23-2022, 03:15 PM   #12
Uk2019
UK2019
If I'm just using a jack (i.e. Not getting under the car) I use the lift pad. If I'm jacking the car up and putting it on jack stands, I jack it up on the bolts that hold the bracing to the pinch welds and put the stands under the lift pads. Since the lift pads protrude lower than the bolts there's less chance of contacting the rocker with the jack than using the bolts.
Old 09-23-2022, 03:55 PM   #13
L2SS455
L2SS455's Avatar
Drives: VOM 2022 2SS
Give the guys at Jiffy Lube $20 bucks and showed them where to put them on since they have that pit right under the car.
L2SS455 is offline   Reply With Quote
Old 09-23-2022, 04:00 PM   #14
RayKinStL
RayKinStL's Avatar
Drives: 2022 LT1
I wish they'd let me just rent that pit for 20 minutes. Even after I have the lift pads on, I think installing this skip shift eliminator is still going to be a huge pain in the ass. I wish I just had access to some sort of lift or similar set up for that install.
