Old 09-15-2022, 02:21 PM   #1
Calnorb
Drives: 2021 LT1 (wife's), 2022 ZL1 (mine)
Underhood insulation missing
I noted before that on my 2022 ZL1 (I took delivery on Nov.6 2021), there is no underhood insulation. I thought this is normal but then I saw pictures of ZL1s that have it. I read on GM Authority, that some were built without due to supply chain problems, does anybody know more? Can they get retrofitted?
Calnorb is offline   Reply With Quote
Old 09-15-2022, 03:54 PM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
When you say underhood... do you mean literally attached to the bottom of the hood? If so, I dont think that was ever included, at least not on ZLE
Old 09-15-2022, 04:12 PM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I have never seen a ZL1 with the underwood insulation.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 09-15-2022, 04:51 PM   #4
As far as I know, the 6th gen ZL1 never had underhood insulation and the supply chain issue affected only lower trims. Are you sure the ZL1 photos you saw had OEM insulation?
Also, this would actually make less sense on a ZL1 with its high strung supercharger, hot engine bay and most people wanting to hear the S/C whine "unmuffled".
Old 09-15-2022, 06:41 PM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
My 2017 ZL1 doesn’t have any under hood insulation and it’s stock.
Old 09-15-2022, 07:04 PM   #6
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Neither does mine. 19 ZLE.
Old 09-15-2022, 07:23 PM   #7
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
No insulation.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 09-15-2022, 07:28 PM   #8
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
2017 ZL1, Stock, None in mine
george is offline   Reply With Quote
Old 09-16-2022, 07:31 AM   #9
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Neither does my 2017
