Old 09-14-2022, 01:42 PM   #1
Zackeery
Drives: 2013 silver camaro ss
Unhappy 2018 1le radial problems
Hello, I recently bought some 17in radials from a buddy. After throwing them on the car everything seems to be fine but after about 2-3 minutes of highway driving, I’m receiving a “service stabilitrak” and “service rear axle” message. It throws the car into quiet mode and turns off ABS and stabilitrak.
I took the car to a place where I could see under it without jacking it up to see if anything is hitting but I couldn’t find anything, which leads me to believe it is just something to do with the sensors.
My question is, what steps should I be taking now?
Would spacers fix this issue?
Those with 17in radials, what tire size are you guys running? It’s sitting on 275/40ZR17 currently and I didn’t think that would be a issue. My front tire size is 285/30ZR20.
Zackeery is offline   Reply With Quote
Old 09-14-2022, 01:53 PM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
sounds as if youre outside the envelope of tire diameter and it's setting off the system, this is definitely a thing that can happen when you go outside the systems parameters like the wheel is turning faster, or slower and the system wigs out.
Old 09-14-2022, 01:55 PM   #3
WhiteMale
use this to see how very different that tire is over the stock 305/20
https://tiresize.com/comparison/
Old 09-14-2022, 02:12 PM   #4
Zackeery
So really it’s just the tire size, Am I able to keep these 17in rims and just switch the tire? Or Is there a way to fix this without switching the tires?
May be a dumb question but is this going to affect anything with my suspension components?
Old 09-14-2022, 02:49 PM   #5
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
You need a tire that is very close to the OEM tire's diameter. Rim size doesn't matter.
Briland_1LE is offline   Reply With Quote
Old 09-14-2022, 04:12 PM   #6
Zackeery
Thank you, that’s what I was thinking.
Old 09-14-2022, 04:17 PM   #7
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Your diameter diff is 6.9% You want to keep that below 4% at most from what I have gathered.
Old 09-14-2022, 05:08 PM   #8
Aquarius
Aquarius's Avatar
Drives: Rapid Blue 2022 Camaro 1SS
Problem you will run across is, with a 17" tire, you could have a rathe tall side wall, which may make finding the right size tires interesting as well and make the car feel like it's floating around when you make a turn. I do not know how much of a problem either of these will cause you, but you do want to be aware of them before you buy a tire.
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000
11/4/2021 - 3100 Status TPW 11/15
11/9/2021 - 3400 Status TPW 11/15
11/24/2021 - 3800 Status built 11/21/2021
12/2/2021 - 5000 Status
12/13/2021 - 6000 Status
Aquarius is offline   Reply With Quote
Old 09-14-2022, 06:58 PM   #9
s346k
s346k's Avatar
Drives: like an old lady
you need a 26" front tire, as well. i used an 18x5 with a mt sportsman sr front tire. i wouldn't suggest making pulls with the current setup, the car will be all over the place.
Old 09-28-2022, 10:45 PM   #10
margoperez
Drives: Camaro 2016 1SS
My friend the same situation but apparently it is difficult to find a specialist to help.
The 2016 College Chevrolet Camaro ranks near the top of the sports car class thanks to its excellent reliability rating, thrilling performance, and feature-filled interior.
margoperez is offline   Reply With Quote
Old 09-29-2022, 09:03 AM   #11
LT1gen6
LT1gen6's Avatar
Drives: '22 LT1 Coupe
Curious. Why the need to go from stock wheel sizes with 1LE package, to small wheels with tall sidewalls tires and loss of handling capability? It's not unheard of in snowy, icy Michigan for those that drive year round, with slightly smaller wheels and snow tires. Wondering about San Antonio reasons
LT1gen6 is offline   Reply With Quote
Old 09-29-2022, 09:04 AM   #12
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Stock tire height 25.7". I think you can go down about 1 " no problem.
Gen6cyl is offline   Reply With Quote
Old 09-29-2022, 09:12 AM   #13
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
305 tires will fix it, happened to me with trying to run a 28 inch rear and 26 front. tires need to be same height.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 09-29-2022, 11:28 AM   #14
FlukeSS
FlukeSS's Avatar
305/45R17 is recommended I thought? I'm sure 40 won't be a huge diff but might be a enough to still flag?
