Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Blue smoke after MM catch can or other catch cans?
I've been noticing some smoke even while idling at stop lights. It started soon after getting a ported stock intake, ported ZR1 TB, longtubes with off road connections and E85 sensor. It really seemed to start after the first tank of E85. Not sure if there is any connection, but while at Roebling Road Raceway this weekend, my friend's dad pointed it out.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
Could it perhaps be the E85?
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Blue smoke usually means you're burning oil. I'd look over the catch can and make sure everything is set up right.
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Likely from the off-road headers and not your catch can. If the tune is even barely off, then you will be shooting fuel out of your exhaust valve close event and it will come out as black smoke if you dont have cats.
If its actually blue and not black, then you are burning some oil for some reason Last edited by Katech_Zach; 09-14-2022 at 07:57 AM. |
Moderator
Agreed. Not sure if the OP has aftermarket valve covers but the baffling is not as good as OEM and ends up filling catch cans with oil in a hurry.
Shifts under load
Thanks. Stock valve covers. It's definitely blue smoke due to oil. It just started right after all the work, so I have a hard time believing valvestem seals, but I know anything is possible. I'm running 93 octane. I did one tank of E85 a few weeks ago.
#7 |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Do you have a flex fuel kit installed?
#8 |
Shifts under load
Yes, and Pray Performance tune and all work done there.
#9 |
Sorry, I am an idiot and missed it in your first post!
