Old 09-13-2022, 09:30 PM   #1
Jrwimmer
Drives: 2022 Camaro ZL1
Break in Period
Just got me 23 Zl1 M6
What is the recommended break in period / maintenance
I've read a lot of things. I really want to get into it but i only currently have had time to drive about 70 miles
Jrwimmer is offline   Reply With Quote
Old 09-13-2022, 09:32 PM   #2
Vigilante375
Drives: 2018 Camaro ZL1
There is a thread posted at the top of this forum call 500/1500 mile and beyond service info. Read that.
Old 09-13-2022, 09:45 PM   #3
Jrwimmer
I didn't see anything regarding how fast / RPM you should or not go etc
Old 09-13-2022, 10:05 PM   #4
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
What I do - leave it in low gears like 1st, 2nd on med throttle rev to 3k ish then let off and let it coast down (don't press in the clutch - let the engine slow you down), accelerate up, repeat. This puts load on both sides of the cylinder walls. Do this as often as possible in the first 500 miles. Downshift all the time and use engine braking often in general. Use rev matching.
wakespeak is offline   Reply With Quote
Old 09-13-2022, 10:08 PM   #5
Apexslayer
Drives: Zl1 1le
Proper break-in is in the manual...
Apexslayer is offline   Reply With Quote
Old 09-13-2022, 10:49 PM   #6
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Well Breakin procedure is going to vary depending on who you ask. The MOST respected engine builder I know, LATE MODEL ENGINES simply told me to drive it like I stole it.
We had some breakin oil from AMSOIL in my freshly built 416 and we changed that after 500 miles so I was relatively easy on it until I could get my 15-50W normal synthetic in it.
Brian at LME told be because of the way the cylinder walls are honed and cross hatched on THEIR engines that ring seal is ALMOST immediate.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-13-2022, 11:04 PM   #7
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Don't baby it, but don't rev it out past 4000 rpm too often, and not near redline. Change engine oil and rear differential oil (with the OEM rear diff fluid specifically for the elec. LSD) at 1000 miles and then enjoy.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 09-13-2022, 11:12 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Mine was dyno'd at 350 miles, and although I haven't taken it apart and inspected the parts, it seems no worse for the wear.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 09-13-2022, 11:45 PM   #9
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Lol. Same, mine went on the dyno with about 220 miles on it, had a 2650 put on it and was given 'full send' again. Drive the car, my answer to this.
Schlok is offline   Reply With Quote
Old 09-14-2022, 03:45 AM   #10
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
My 2016 Z06 had a lower redline on the tach for the first 500 miles. Does the ZL1 not do that?
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black
Jus Cruisin is offline   Reply With Quote
Old 09-14-2022, 07:36 AM   #11
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Go by the owners manual recommendations and you should be good to go! ��
Old 09-14-2022, 07:58 AM   #12
No, that's a Corvette-only feature.
Old 09-14-2022, 09:26 AM   #13
Vigilante375
The Blackwing has it as well now.
Old 09-14-2022, 09:28 AM   #14
Vigilante375
The very first section, preliminary, has a hyper link to a track prep guide that tells you exactly how to break in the car per GM.
