![]() Drives: SS 1LE Join Date: Sep 2022
Simple Tire Trailer - First attempt
Thought i'd share with you guys my attempt at building a tire trailer. So far no issues at super happy with the result. Not the best setup compared to the custom builds I've been seeing, but no issues and pretty good weight balance fully packed.
Trailer is the standard aluminum harbor freight most use with simple with wood base and bunch of home depot mounting hardware. I added metal weather proof box up front to help with tongue weight and tool box and fuel jugs with a small ice chest in the middle secured with straps. |
![]() Drives: '21 V6 1LE Join Date: Jul 2020
Thanks for sharing - that looks awesome!
Shadow Gray '19 ZLE M6
Absolutely love this. I have been considering doing the same with a HF trailer. Which trailer hitch? And did you have to cut the bumper or diffuser at all?
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Been thinking of doin the same as well but using a single jet ski trailer.
Orange Krush II
#5 | |
thx , definitely worth the effort if your willing to do it. CURT 11900 1 1/4 hitch is what i used direct bolt in but you do have to trim a few inches from the very bottom of the bumper, but honestly not really noticeable straight on and from above can't see at all. If i removed the hitch i doubt anyone would even notice the part that was cut. |
#6 | |
#7 |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I love these setups with the little trailer I really thought about this as an option but I ended up getting a car trailer though so I'm looking forward to using that in the future. It should be much better to drive to and from the track, also gives me the ability to go to tracks much further away. This is a great option for opening up the ability to use slicks on the track though.
Now I have a real life trailer, a camaro and a BMW that can't pull the trailer, need to sell the BMW and get a tow car(probably a touareg) |
#8 |
![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Good Job!!!
Nice job!!! I know I enjoy mine https://www.camaro6.com/forums/showt...t=tire+trailer . Looks like most of the weight is towards the back of the trailer like you want. I would make sure you use trailer tires with M rating (81 MPH) or HIGHER. https://www.etrailer.com/dept-pg-Tra...nd_Wheels.aspx
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 09-12-2022 at 09:42 PM. |
#9 | |
Interesting, never looked into these because i never thought of replacing the tires. Might switch to these before the next road trip. Just makes sense really. |
#10 | |
I LOVE the matching color on your trailer wheels to your car wheels. SUPER NICE>
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
