Old 09-10-2022, 11:36 PM   #1
jchamp922
Drives: 2022 Zl1
Interior Vibration
Driving my Zl1 today and noticed a loud vibration coming from the rear interior when accelerating. Traced it to the rear passenger side seat. Lifted the bottom back seat and you can really hear it. Anybody experience this before. Any ideas before I bring it to the dealer. Thanks
jchamp922 is offline   Reply With Quote
Old 09-11-2022, 07:56 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Passenger side speaker is the common culprit.
https://www.camaro6.com/forums/showthread.php?t=561747
Old 09-11-2022, 09:06 AM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Mine does it too but I’m not going to take it anywhere to get it checked. I will just live with it since it is a 650 hp hotrod! Good luck with yours.
Old 09-11-2022, 09:49 AM   #4
jchamp922
Drives: 2022 Zl1
Somebody posted about a fuel feed pipe vibration. Under the rear passenger side bottom is the gas tank.
Old 09-11-2022, 02:29 PM   #5
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I have some sort of rattle originating from the upper deck in the back where the speakers sit on. Everything looks right so I don't know what the heck it could be. I have not entirely attempted to isolate what it is yet though. Anybody know what causes it?
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ
Old 09-11-2022, 07:57 PM   #6
raptor5244
Drives: 2022 CT4-V Blackwing
My 2021 ZL1 did the same. I just turn the radio up and make sure exhaust is in Track Mode.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 09-12-2022, 12:10 AM   #7
LT4Greg
LT4Greg's Avatar
Same here raptor!��
Old 09-12-2022, 01:56 PM   #8
jchamp922
Drives: 2022 Zl1
Made appointment for service. Let's see what they tell me.
Old 09-12-2022, 08:56 PM   #9
jchamp922
Drives: 2022 Zl1
Drove car today no vibration.
Old 07-23-2023, 06:23 PM   #10
jchamp922
Drives: 2022 Zl1
Vibration came back today but when i filled car up with gas went away Maybe it's that fuel feed pipe bulletin that came out a while ago. Car is a 2022
Old 09-23-2023, 02:06 PM   #11
jchamp922
Drives: 2022 Zl1
Car is at the dealer for vibration. They are trying to tell me it might have to do with exhaust. Made noise even with stock exhaust. Get louder as car gets hotter. I am thinking it's has something to do with the fuel control module in the tank because you can hear the noise inside the tank. All this was told to dealer. I am providing a sound clip if anybody has any ideas
https://photos.app.goo.gl/1qKr44LxG63zgvvM8
Old 09-26-2023, 09:03 PM   #12
jchamp922
Drives: 2022 Zl1
Dealer got back to me today and said diff cooler line was loose causing the vibration
Old 09-27-2023, 07:43 AM   #13
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Interesting.
Old 01-03-2026, 06:16 PM   #14
Bird71
Drives: '22 ZL1 A10
Jchamp... I know this is an old post but did the dealer fix cure your vibration. I also have a '22 with the same issue.
'22 ZL1 A10 Riverside Blue Coupe
Katech 103 TB, RF Big Gulp, Katech ported SC, Griptec 2.3" Upper, Katech 160* Thermostat, CT5 BW Oversized Front Brake Air Deflectors,
BMR Rear Cradle Lockout, JRE Oversized Crankcase Vent Hose; Katech ECM/TCM tuned - 593whp/579wtq (Mustang Dyno)
Bird71 is offline   Reply With Quote
