Old 09-10-2022, 07:49 PM   #1
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
Cool BMR BK063 Rear Cradle Lockout Review
Parts:
1. BMR BK063 Rear Cradle Lockout Kit
Sold Separately
2. Forward, Rear Cradle Bolts: Part # 11547921 (74ftlbs + 90- 105 degrees)
3. Rearward, Rear Cradle Bolts/Stud: Part # 11611819 (74ftlbs + 90-105 degrees)
Installed at: Redline Motosports, Florida - 1 to 1.5 hours
Car: 2017 Camaro zl1 M6 with breathing mods - weekend car
The BMR BK063 is necessary to greatly reduce slop and movement of the OEM rubber cradle bushings!
Before Install:
1. Flat footed acceleration was smooth yet damped, almost like a roll into speed.
2. Rear end would move unpredictably at high speeds while changing lanes over un even pavement and become slightly unsettled over pavement lane reflectors.
3. While changing lanes quickly, rear end would catch up to the front end.
4. Taking sharp high speed turns, the rear would "waggle" and was not confidence inspiring.
AFTER Install: (seat time - 3 days approx: 50 miles)
1. YOU CAN FEEL EVERY BIT OF ACCELERATION FROM ANY PEDDLE POSITION!
2. Rear end stays planted while changing lanes over un even pavement with no lateral movement.
3. The rear end moves DIRECTLY inline with the front end during acceleration while performing spirited lane changes.
4. Taking turns IS NIGHT AND DAY compared to stock, confidence up 90%!!
Conclusion:
Shame on GM for not making this device factory!
If you have not done this mod on a regular ZL m6, you are truly missing what our cars feel like with hardly no wheel hop....this is truly a bolt-on where you WILL FEEL THE DIFFERENCE IMMEDIATELY!!
Shout out to Howard from Redline Motorsports!!
Krowser is offline   Reply With Quote
Old 09-10-2022, 08:30 PM   #2
AZIROC
Drives: '86 IROC-Z '18 ZL1
Sounds good. I keep going back and forth on this and the 1le kit. The plus to this kit is you can do it in your garage vs the 1le needs the cradle to be dropped.
Old 09-10-2022, 09:20 PM   #3
Krowser
Krowser's Avatar
Correct!...I also understand the 1LE kit will increase NVH...the BK063 kit does not,,
Old 09-10-2022, 10:42 PM   #4
AZIROC
The car is mainly on the track so NVH is fine.
Old 09-11-2022, 01:19 AM   #5
clg82
Drives: 2020 Camaro ZL1
Huh? I just looked at the BMR instructions and multiple times it mentions the cradle needing to be tilted or dropped…..
Old 09-11-2022, 05:06 AM   #6
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
He did the lockout kit. The cradle only has to drop a tiny bit to get the bits in. It's not a true solid bushing. The kit only fills the gaps in the factory bushings. I had the same kit on my 17', and it does make a difference. I plan to do the solid bushings on my current car.
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 09-11-2022, 06:37 AM   #7
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Very nice kit for sure. Had it and all BMR arms on my 19 and the rear felt drastically better. When my new gets here I’ll do the cradle and diff lockout on it.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 09-11-2022, 07:00 AM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
works great..it made a noticeable improvement in my '17 ZL1
Old 09-11-2022, 07:55 AM   #9
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
For those inquiring minds......the install video.......
2022 ZL1 Summit White A10
2020 GT350 Heritage Edition-Chassis L0350
2019 ZL1 Summit White M6
2018 Hellcat White Knuckle M6
2016 Hellcat GoMango A8
2002 Dodge Viper Viper Red
2002 Corvette Z06 Millennium Yellow
1998 Dodge Viper Viper Silver Metallic
Firecaptain is offline   Reply With Quote
Old 09-11-2022, 08:27 AM   #10
Z OH 6
Drives: 2024 CT5-V Blackwing
You get 95% of the same performance as the 1LE pieces at a fraction of the cost and much easier installation. It's a no brainer really.
Old 09-11-2022, 08:34 AM   #11
Smokin19
Drives: 19' ZL1 A10, w/pdr
I am happy with the results of my BMR lockout kit install.
Smokin19 is offline   Reply With Quote
Old 09-11-2022, 11:17 AM   #12
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
This is on my list of first mods for sure.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 09-11-2022, 11:46 AM   #13
I have the same BK063 lockout kit, its price is actually the same as the ZL1 1LE solid bushings (or at least it was when I bought it), but installation is way easier indeed.
Old 09-11-2022, 11:49 AM   #14
Z OH 6
I thought the 1LE solid bushing kit was over $500, last time someone posted it, maybe I'm wrong.
